various distributions of returns
Posted: Mon Sep 01, 2025 1:58 am
by ac_1
In RATS (using the various models from GARCHUV.RPF):
(a) How do I plot the PDF Fit from a (G)ARCH-family model superimposed on the raw returns, as (G)ARCH-family says returns are distributed around the mean with volatility sigma(t)?
(b) I want a diagnostic check (the assumption about the innovations), so plot the standardized residuals eps(t)/sigma(t) against the assumed pdf (Normal/t/GED). How?
Additionally,
* Normal overlay
@histogram(distrib=normal,maxgrid=100,$
           header="distribution of log-returns dlogdm overlay of the normal density") dlogdm
* KDE overlay
density dlogdm / sgrid sdensity
density(type=histogram) dlogdm / hgrid hdensity
scatter(style=bargraph,overlay=line,header='kernel estimates of the distribution of log-returns dlogdm') 2
# hgrid hdensity
# sgrid sdensity
Can the black density histogram be plotted with just a border for each bar i.e. no colour. How about other colours rather than black, or shading/patterns?
Further, how would I overlay all 3: normal, KDE and GARCH PDF Fit, with the histogram of the returns?
thanks,
Amarjit
Re: various distributions of returns
Posted: Tue Sep 02, 2025 9:10 am
I have no idea what you mean about the GARCH "PDF". There's a different variance for each data point so you only get one observation on each.
The histogram and the kernel density are two alternative views of the same information. You generally would not show both on a single graph. (That would typically be done only to demonstrate what a kernel density does).
Graph styles/colors are described on:
https://estima.com/webhelp/topics/graph ... mbers.html
https://estima.com/webhelp/topics/stylesheets.html
The 3rd example on SCATTER shows calculation of an empirical density function graphed against the true density:
https://estima.com/webhelp/topics/scatt ... ction.html
Posted: Wed Sep 03, 2025 2:47 am
by ac_1
TomDoan wrote: Tue Sep 02, 2025 9:10 am I have no idea what you mean about the GARCH "PDF". There's a different variance for each data point so you only get one observation on each.
Sorry, my error, (G)ARCH-family model(s) do not directly produce a probability density function (PDF) Fit to the returns.
Posted: Thu Sep 04, 2025 12:22 am
by ac_1
If I want to graph the
standardized residuals diagnostics:
- Histogram of residuals with an overlay against the assumed pdf (Normal/t/GED)
- Helps check if volatility model captures heteroskedasticity.
within a loop, RATS will generate lots of graphs.
I would like just ONE graph being overwritten, as I traverse through the loop.
Is there an option?
Posted: Thu Sep 04, 2025 8:52 am
There's a preference item (Graphics tab) for "One Graph Window Only?". I seriously doubt that you will find that useful. You would be overwriting its contents maybe 10 to 50 times a second.
Posted: Fri Sep 05, 2025 2:41 am
by ac_1
TomDoan wrote: Thu Sep 04, 2025 8:52 am There's a preference item (Graphics tab) for "One Graph Window Only?". I seriously doubt that you will find that useful. You would be overwriting its contents maybe 10 to 50 times a second.
If I do something like:
comp rend = 800
do jj = 0, 50
   garch(p=1,q=1,resids=u,hseries=h,print,METHOD=BFGS,stdresids=stdu) 2 rend+jj y
   set stdusq 2 rend+jj = stdu(1)^2
   @histogram(distrib=normal) stdusq 2 rend+jj
end do jj
I get 51 graphs.
Preferences -> One Graph Window Only
I get one graph window, and sometimes get an "animation", sometimes not, as RATS crashes. Animations are useful, especially over a long history of time, here, to see what's in the tail's when using rolling/recursive windows. Presumably, slow-down the graphing somehow?
Posted: Fri Sep 05, 2025 8:38 am
The one graph option is a throw back to the earlier days of Windows when you could be severely limited in how many windows could be handled by the operating system (and computers were 100 times slower than today so graphs wouldn't be overwritten multiple times a second).
