Long-run solution of the estimated STAR models
Posted: Thu Oct 30, 2025 3:55 am
I have an estimated nonlinear STAR model, which now behaves like a linear model. I would like to estimate its long-run solution. When the transition function takes the extreme values of F = 0 and F = 1, I want to determine where the model converges after applying a shock. I could not find a suitable code for this purpose. I believe an approach similar to an impulse–response function might be appropriate. What kind of code should I run?
Thank you,
Best.
Thank you,
Best.
