Variable Specific Prior (Mean) Restrictions on BVARs
Posted: Sat Sep 19, 2009 3:30 am
by rangangupta
Suppose, I have a VAR model with two variables, one stationary and the other non-stationary.
I was wondering if, while estimating a BVAR model with these two variables, it is possible to impose a prior mean of 0 on the first own lag of the stationary variable, while continuing to impose a prior mean of 1 on the first-own lag of the non-stationary variable.
I know the from the drop down menu (Statistics -> VAR (Setup/Estimate)) allows me to choose 0 or 1 as the prior mean on the first own lag of a variable in a VAR, but not really sure how I can make it variable specific depending on whether it is stationary or non-stationary.
Any help would be highly appreciated.
Regards
Rangan
Re: Variable Specific Prior (Mean) Restrictions on BVARs
Posted: Sat Sep 19, 2009 9:28 am
The wizards don't include some of the less-used options. (With too many choices, they can get confusing).
SPECIFY has an MVECTOR option, which in your case would be MVECTOR=||1.0,0.0|| if the 1st variable is the non-stationary and 2nd is stationary (and ||0.0,1.0|| if they're reversed). You can just take the instructions generated by the wizard and edit the SPECIFY to put the MVECTOR option in. (Take the MEAN option out if it's in your SPECIFY).
Posted: Sat Sep 19, 2009 1:17 pm
by Gary
Hi there,
I have a similar question to Rangan's below. I am running a 5 variable BVAR with 3 foreign and 2 domestic variables. I am treating the foreign variables as block exogenous, but not imposing exogeneity directly using the near-VAR approach. Instead, I want to shrink the parameters on the domestic variables to zero in the equations for the foreign variables.
This is less restrictive than the near-VAR approach, as it allows for a non-zero posterior in the event the data strongly disagrees with the prior. What I have done is to use the specify(type=general) option with a declared 5 x 5 prior matrix, with zero's placed on the 04th and 05th elements in the first, second, and third equations ( the three foreign variables are ordered first in the VAR). Is this the correct way to do it, or do I need to use a "dummy observation" prior? Are there any examples of the dummy observation prior approach that I can use for reference?
Many thanks in advance for your help
Best wishes,
Gary
Posted: Sat Sep 19, 2009 5:24 pm
That's the right idea, but you can't do a hard zero because it needs to divide by the value. Use a value number like .0001 instead. If you look at the CANMODEL.PRG example, the final model run there nearly zeros out several of the lags.
Posted: Sat Sep 19, 2009 7:43 pm
by Gary
Many thanks, much appreciated. The procedure seems to work all right - the impulse responses of the foreign variables are fairly flat around zero as far as domestic shocks are concerned.
Best wishes,
Gary.
Posted: Sun Sep 20, 2009 3:05 pm
by rangangupta
Thanks a lot. Really appreciate this.
Regards
Rangan
