R squared for VAR -Estimation by cointegrated least square
Posted: Wed Oct 28, 2009 10:57 am
by Nadiarock1
I would like to have an advice for getting the R-Squared from a VAR/system - Estimation by Cointegrated least Square.
1. I have estimated a Fm-ols and I saved the coefficients (long run)
2. I use these coefficients in a ECM models to get the short-run parameters. .
But, I got a problem with the variables I specified and I would like to have the R-Square parameter to insure me that my equation system is ok.
How can I get this R squared in a system by cointegrated least squares.
Thank you.
Nadia
Re: R squared for VAR -Estimation by cointegrated least square
Posted: Mon Nov 02, 2009 4:46 pm
by moderator
What formula for the R-square did you have in mind?
Tom Maycock
Posted: Tue Nov 03, 2009 10:24 am
by Nadiarock1
I would like to use the Ajusted R-squared.
I have modified some of the programs I used to incorporate this code (%RBARSQ ) after linreg and it worked.
The next step is to get a R-squared with the VAR/Cointegrated.
Here is my code for the VAR/cointegrated. If I had a @source, I would go it that file and add the command for R-Squared, but with the command "system" I don't know how to use it. If I add it at the end of the following code, I got only 1 R-squared for the entire VAR/cointegrated system.
system(model=ectmodel)
variables y1 y2 x1
lags nlags
det constant tariff d import gdp
ect producersupport
estimate
Thank you very much, Nad
Posted: Tue Nov 03, 2009 10:47 am
Nadiarock1 wrote:Hi,
variables y1 y2 x1
lags nlags
ect producersupport
estimate
I think you want that to be
lags 1 to nlags
If you add this after your code above, you'll get a vector of the standard centered R-squareds:
compute varsigma=%sigma
vcv(center,matrix=basesigma) %regstart() %regend()
# dm dy
compute rsquared=1.-%xdiag(varsigma)./%xdiag(basesigma)
The R-bar squared is computed with:
compute rsquared=1.-(%nobs-1.0)/(%nobs-%nreg)*%xdiag(varsigma)./%xdiag(basesigma)
Is there are particular reason you wanted this? It's not included because it's almost never reported. With non-stationary data, they're generally numbers like .99999.
Posted: Tue Nov 03, 2009 12:20 pm
by Nadiarock1
I want to get the R-squared from my VAR/Cointegrated because I have a problem with the signifiance of the ECM for the sort run and the Error correction term. Basically, I have unit roots and cointegration for my variables in my database. I estimate a fmols with good significance with expected coefficient signs and a quite good R².
Then, I want to use these long run coefficients previously estimated with the fmols for the long run and use it with the ECM. When I get the VAR/cointegrated of my systems, the sort run as well as the error correction term become non-significant. As you has written, the r-square is 0.99 in my system...hmmm. Also, there is no multicollinearity..
Do I have to difference my exogeneous variables that have unit root? By definition, the endogenous are differenced in the VAR/Cointegrated. I try to find out why I get the results.
Thanks again.
Nadia
Posted: Thu Nov 05, 2009 2:15 pm
If you're using SYSTEM with ECT, then no, you don't difference the variables. The inclusion of the proper forms for the endogenous variables is handled automatically when you do an ESTIMATE.
