GARCH Forecasting with GARCHFORE and MVGARCHFORE
Posted: Wed Apr 11, 2007 11:36 am
by TomM
This is an example which uses MVGARCHFORE in a non-trivial fashion. Note that because "h" is a SERIES[SYMMETRIC], you reference its elements as h(time)(i,j).
This also demonstrates the univariate forecasting procedure, GARCHFORE.
The example is from Ruey Tsay's Analysis of Financial Time Series.
* Tsay, Analysis of Financial Time Series, 3rd edition
* Example from section 10.7 from pp 546-548
open data d-spcscointc.txt
data(format=free,org=columns) 1 2275 sp500 cisco intel
* Create the two mean equations, and group them into a model
equation eq1 cisco
# constant cisco{1 2 3}
equation eq2 intel
# constant
group bimodel eq1 eq2
* Do the univariate GARCH models and forecast the variances. (You need
* to do the variance forecasts immediately after the GARCH instruction)
garch(equation=eq1,p=1,q=1,resids=a1,hseries=h1)
@garchfore(steps=1) h1 a1
garch(equation=eq2,p=1,q=1,resids=a2,hseries=h2)
@garchfore(steps=1) h2 a2
* Forecast the means
forecast(model=bimodel,steps=1,results=rhat)
compute q1=rhat(1)(2276)+%invnormal(.05)*sqrt(h1(2276))
compute q2=rhat(2)(2276)+%invnormal(.05)*sqrt(h2(2276))
vcv(noprint)
# a1 a2
compute rho=%sigma(1,2)/sqrt(%sigma(1,1)*%sigma(2,2))
compute q12=sqrt(q1^2+q2^2+2*rho*q1*q2)
disp "Univariate Models"
disp "VaR on Cisco" @20 -10000*q1
disp "VaR on Intel" @20 -10000*q2
disp "VaR Overall" @20 10000*q12
garch(model=bimodel,p=1,q=1,mv=cc,hmatrices=h,rvectors=a)
@mvgarchfore(steps=1,mv=cc) h a
compute q1=rhat(1)(2276)+%invnormal(.05)*sqrt(h(2276)(1,1))
compute q2=rhat(2)(2276)+%invnormal(.05)*sqrt(h(2276)(2,2))
compute rho=h(2276)(1,2)/sqrt(h(2276)(1,1)*h(2276)(2,2))
disp "Bivariate Model"
Data file:
d-spcscointc.txt
(55.57 KiB) Downloaded 1377 times
Posted: Wed Apr 18, 2007 10:33 am
by HinderAlex
Hi, where can I find the data file d-spcscointc.txt? I am still using RATS version 6.20. :?:
Posted: Wed Apr 18, 2007 3:16 pm
by TomM
You can find the data files on Ruey Tsay's web site. The link in our "textbook examples" section should take you there.
Or order RATS 6.35, which will be shipping in a few days.
Re: GARCH Forecasting with GARCHFORE and MVGARCHFORE
Posted: Fri Oct 17, 2008 4:37 pm
by Gregory
TomM wrote: *
I tried running this with my own series. Everything works fine until this point. I get NA for the VaRs. What does the @20 refer to? If it is a line result, then that may be my problem because I added a couple of lines to the code.
Posted: Mon Oct 20, 2008 11:40 am
The @20's will have no effect on the values - they just position all the VaR values to the same position in the output.
If you're getting NA's, you should check the pieces that go into the final calculation. The rhat's are the forecast means and the h's are the forecast variances. One or the other has to be NA's. It's more likely to be a problem with the forecasts - you can stick a PRINT option on the FORECAST instruction to see.
