Minor Bug in ADF Procedure
Posted: Tue Nov 14, 2006 8:51 am
by TedKury
Not sure if this is the right forum, but I'll post it here anyway.
On line 140 of the ADF procedure, the SMPL statement within the SELECTUNI subprocedure
SMPL maxlag nobs
will cause problems if series does not begin with entry 1. The line should read
SMPL startl+maxlag-1 startl+nobs-1
This should fix the problem.
Posted: Tue Nov 14, 2006 10:07 am
by TomM
Which "ADF" procedure? Are you referring to the procedure on the old file "ADF.SRC"?
If so, that shouldn't still be available on our website anywhere, as it was superseded years ago by a newer version called "URADF.SRC". Check out URADF.SRC from our website--it should handle entry ranges properly.
Please let me know if you found a copy of ADF.SRC on the current site somewhere, or if you were referring to a different file.
Tom Maycock
Estima
Posted: Tue Nov 14, 2006 11:16 am
by TedKury
Thanks for the pointer, Tom. I really should use your menus to find things. Bad habit. I found the old proc at www.estima.com/procs/adf.src through the website's Search feature.
