Gray GARCH example question (split from MSVAR topic)
Posted: Sat Jan 09, 2010 3:25 pm
by GUESMI2010
until the new version of RATS, I applied the paper GARY 1996, I found the results with the database of gray, but with my database I found difficult.
I send you my database and the program GRAY .
THANK YOU VERY MUCH
Re: MSVARSetup - Markov switching support procedures
Posted: Sat Jan 09, 2010 3:46 pm
by GUESMI2010
Here is the program and I thank you in advance.
Posted: Mon Jan 11, 2010 9:12 am
You posted the program for the original data set; not yours. That won't help us.
However, it's not surprising that you're having problems with the Gray model. It does not have a very well-behaved "likelihood function" as you can tell from the comments in our post. There are likely multiple modes with similar likelihood values but very different sets of parameters. I put likelihood function in quotes since it isn't the true likelihood. In order to avoid problems with path-dependence, it simplifies the lagged variance at each step. I don't know whether the source of the messy likelihood surface is that simplification, or whether it's the general problem of multiple modes shared by many switching models.
Posted: Mon Jan 11, 2010 10:38 am
by GUESMI2010
I thank you for the information and here is my base.
thank you very much.
Posted: Mon Jan 11, 2010 1:04 pm
That's your data set again. You said that you weren't able to get it to work with your data set. We need to see the program that didn't work correctly.
Posted: Tue Jan 12, 2010 5:07 pm
by GUESMI2010
Hi TOM,
Here is my program, the problem is that I can not leave the graph probabilities.
Best regards
Posted: Wed Jan 13, 2010 10:10 am
It looks as if one state is probably fine which would explain the difficulty in getting a two state model to fit.
