Return Spillover effect in MGARCH-BEKK
Posted: Mon Apr 12, 2010 8:12 pm
by prashantj
I wish to examine the return spillover effects of various stock markets. The result that MGARCH-BEKK reports does contain parameters like mean, C, A, G and D where C=lower triangular matrix of constant, A=Arch term, G=garch term and D=asymm. parameters. The output does not have return spillover parameter (return is of stock market return series( for my research) under investigation) to measure cross market return spillover like results presented by A, G and D term. May I Know How do I measure return spillover from one market to another like A and G spillover results? Can anyone help? I shall be grateful for the reply.
Re: Return Spillover effect in MGARCH-BEKK
Posted: Tue Apr 13, 2010 1:17 pm
You need to do a VAR(1) mean model. See, for example,
http://www.estima.com/forum/viewtopic.php?f=11&t=362
The modernized code is several posts down in that thread. What you want is similar, but using MV=BEKK.
Posted: Sat Apr 17, 2010 2:27 am
by prashantj
I estimated following equation :
garch(model=var1,mv=bekk,hmatrices=h,rvector=r,pmethod=simplex,piters=90,method=bfgs,iters=600,asymmetric) / dlhsid DLJKSE DLKS11 dln225 dlsse dlbse
here six variables are stock market return series. Each return series is multiplied with 100. It displays the output with the following message:
NO CONVERGENCE IN 306 ITERATIONS
LAST CRITERION WAS 0.0000000
ESTIMATION POSSIBLY HAS STALLED OR MACHINE ROUNDOFF IS MAKING FURTHER PROGRESS DIFFICULT.
TRY HIGHER SUBITERATIONS LIMIT, TIGHTER CVCRIT, DIFFERENT SETTING FOR EXACTLINE OR ALPHA ON NLPAR.
Usable Observations 1481
I have tried with different subiertion limits ranging from 5 to 90. But the same above message found. The process also takes lots of time to get the results. Kindly guide. What to do to achieve the convergence. Looking forward for a reply.
Posted: Sat Apr 17, 2010 8:23 am
That's a really big model to estimate with a BEKK. Since your main interest is in the VAR coefficients, have you tried using a more tightly parameterized GARCH model, such as DCC?
Posted: Sun Apr 18, 2010 5:14 am
by prashantj
TomDoan wrote:That's a really big model to estimate with a BEKK. Since your main interest is in the VAR coefficients, have you tried using a more tightly parameterized GARCH model, such as DCC?
Thanks Tom. I also wish to analyze volatility spillover. DCC does not give cross market spillover effect in volatilty like BEKK. BEKK estimation becomes difficult in my analysis. How do I proceed to analyze cross market spillover effect? Please suggest. Can choosing a small sample period of nearly 900 or 1000 instead of 1481 solve the problem?
Posted: Sun Apr 18, 2010 10:01 am
You might try doing a shorter span first, perhaps for a limited number of iterations, then switching to the full data set. Just use the option INITIAL=%BETA on the second GARCH instruction. You could also repeat the same GARCH instruction, again with INITIAL=%BETA after it stalls. The BFGS estimate of the Hessian can sometimes collapse; restarting the process often works to get things moving again. You might also try switching to METHOD=BHHH after BFGS stalls. BHHH isn't a good choice from the start (since it will generally get the shape quite wrong at the guess values), but once you've done 300+ iterations, you're usually close enough to the optimum that the BHHH shape is more reasonable.
Posted: Wed May 05, 2010 2:22 am
by prashantj
Thanks Tom. Now, I got my results successfully. Again thanks a lot for your help. The help feature of RATS is excellent. This deserves all our appreciation.
