Dynamic Forecast with VECM
Posted: Thu May 20, 2010 6:57 am
Dear RATS/CATS-users,
I've got the following problem. I set up a cointegrated VAR model in CATS, which I then exported to RATS. After that I reset the sample so that all deterministic variables (+exogenous) are defined over the forecasting-sample. I then use RATS VAR Forecast/Analyze option to produce 4-step ahead DYNAMIC Forecasts. The problem is that the forecasts do not change whether I choose 1,2,4 or 8 step ahead dynamic forecasts. Anybody an idea what I'm doing wrong her?
I've got a 5-variate CVAR-model with 2 cointegration vectors. In a dynamic forecast, the differences of the endogenous variables are predicted with each of the simultaneous equations, and based on that also the error correction term should be calculated (so also the cointegration relationship should be "endogenized"). Is this possible with RATS and if so how?
Thanks in advance for any help on this!
