MONTESUR.RPF—Gibbs Sampling for near-VAR
Posted: Mon Sep 17, 2012 3:23 pm
MONTESUR.RPF uses Gibbs sampling for doing impulse responses with error bands for a near-VAR model using a standard Cholesky factorization for the contemporanenous model.
Detailed description
The use of the SUR-Gibbs procedures is described in greater detail in the Bayesian Econometrics e-course.
Re: Gibbs Sampling for near-VAR
Posted: Fri Feb 27, 2015 9:11 am
by viking76
I would like to ask you which kind of prior are you using in the file montesur.rpf. I am not able to figure it out.
Adrian
Posted: Mon Oct 07, 2024 9:45 am
Flat on the coefficients, standard Jeffrey's prior on the covariance matrix.
