Quick questions
Posted: Thu Jul 08, 2010 1:33 am
by ivory4
1. If I declare a
it seems that I need to dimension it if I will use
do i =1 ,10,1
set a 1 5 =%ran(1)
set fc(i) / = a
Otherwise, it says SET needs parameter SERIES
I also noticed that in this way in the series window, if I use a loop where i goes to 1000, all of them will be shown.
Is there a better way to do the same thing?
And I tried rect[series] which is automatically defined if I use COMPUTE
2.
compute count = 10
display count/10
it turns out to be 0 ?
Re: Quick questions
Posted: Thu Jul 08, 2010 9:47 am
by moderator
ivory4 wrote:1. If I declare a
Yes, you need to dimension FC.
For example:
dim fc(10)
do i =1 ,10,1
set fc(i) 1 5 = %ran(1)
I'm not sure what you are asking. Do you mean a better way to view all 1,000 series?
Not sure I follow you there. I don't think that COMPUTE statement will work if A is a series and FC is a rectangular array of series.
ivory4 wrote:
2.
compute count = 10
display count/10
[/quote]
Yes, if you divide an integer by an integer in RATS you get an integer result (i.e. any remainder is truncated). If you want a real-valued answer, one or both terms needs to be real. For example:
display count/10.0
or
display float(count)/10
Tom Maycock
Re: Quick questions
Posted: Thu Jul 08, 2010 11:42 am
by ivory4
I mean by clicking DATA- Show SERIES WINDOW, all fc(i) from 1 to 1000 are there. If i is big, it takes time to show the SERIES WINDOW.
I was wondering if I am recording the series in a cumbersome way.
com a 1 10 =%ran(1)
com f = a~a
disp f(1,1)
I think it works, but it creates rect[MATRIX]?because I need to use DISPLAY
Thanks for the rest of answers.
Re: Quick questions
Posted: Fri Jul 09, 2010 12:45 pm
by moderator
ivory4 wrote:
I mean by clicking DATA- Show SERIES WINDOW, all fc(i) from 1 to 1000 are there. If i is big, it takes time to show the SERIES WINDOW. I was wondering if I am recording the series in a cumbersome way.
It doesn't really matter how you create them--a thousand series are a thousand series, whether you have a thousand individual series or a vector of series.
ivory4 wrote:
com a 1 10 =%ran(1)
com f = a~a
disp f(1,1)
That won't work as written--you would use SET, not COMPUTE, to create A. If you do:
set a 1 10 =%ran(1)
com f = a~a
disp f(1,1)
F will be an ordinary rectangular array of
reals, not a rectangular array of
series.
Do you just need to use DISPLAY to view the values of the series? If so, you can apply it directly to entries of the series. For example:
display a(1)
Tom Maycock
