Checking memory used by RATS
Posted: Tue Aug 24, 2010 6:31 am
by jonasdovern
I coundn't find (or better: remember) the command which allows to check how much memory RATS currently uses. (I am running a Gibbs sampler which would run without error with a small number of iterations, but which crashes RATS when increasing the number of iterations. I would like to check if memory problems are the problem...)
Re: Checking memory used by RATS
Posted: Tue Aug 24, 2010 10:25 am
by moderator
You can do:
SHOW MEMORY
However, if the program is actually crashing (i.e. shutting down spontaneously), it is highly unlikely that it would be do running out of memory.
Tom Maycock
Posted: Wed Aug 25, 2010 2:21 am
by jonasdovern
Thanks. I'll check how the used memory evolves. The program is not actually shutting down - but rather stops working and displays (according to my translation, I have a German system): "Application does not react anymore".
