Small sample bias in VARs
Posted: Thu Sep 09, 2010 2:35 am
by comac
Following the post on “Bootstrapping VAR residuals” (http://www.estima.com/forum/viewtopic.php?f=4&t=669) I am trying to compute the small sample bias for my VAR coefficients. I am taking the RATS example from Lutkepohl's New Introduction to Multiple Time Series Analysis.
Last time you suggested me to compute the matrix total as the bootstrapped estimate of the bias. Unfortunately, the results change evrytime I run the code (which is not what I really want)
I have also tried to play around with the code below but nothing happened. Do you have some suggestion?
open data e1.dat
calendar(q) 1960
set dinc  = log(income/income{1})
set dcons = log(cons/cons{1})
set dinv  = log(invest/invest{1})
system(model=varmodel)
variables dinv dinc dcons
lags 1 2
estimate(sigma,resids=resids) * 1978:4
compute base=%modelgetcoeffs(varmodel)
compute total=%zeros(%rows(base),%cols(base))
@VARBootSetup(model=varmodel) bootvar
compute rstart=%regstart()
compute rend  =%regend()
compute bootdraws=2000
compute nvar  =3
compute nsteps=8
infobox(action=define,progress,lower=1,upper=bootdraws) $
   "Bootstrap Simulations"
do draw=1,bootdraws
   @VARBootDraw(model=varmodel,resids=resids) rstart rend
   * Estimate the model with resampled data
   estimate(noprint,noftests)
   compute total=total+(%modelgetcoeffs(bootvar)-base)
   infobox(current=draw)
end do draw
infobox(action=remove)
compute total=total/bootdraws
[/quote]
Many thanks :D
C.
Re: Small sample bias in VARs
Posted: Thu Sep 09, 2010 10:39 am
I'm a bit confused about your question. Are you concerned that you get a different bootstrap estimate each time you run a bootstrap? If you think the variability is too high, run more draws. If you want to control the draws, use the SEED instruction.
Posted: Fri Sep 10, 2010 1:36 am
by comac
Tom -- sorry if I was unclear. Anyway, I wanted exactly to set the seeds for the random number generator. Thanks a lot.
