Markov model
Posted: Thu Sep 30, 2010 4:06 pm
by terrya
Is it possible to use RATS to estimate a model like the one on p 28 of the file below? If so how can the code be modified for the MSVar?
http://www.rbnz.govt.nz/research/bullet ... wallis.pdf
Re: Markov model
Posted: Thu Sep 30, 2010 4:26 pm
The MSVAR is quite a bit more complicated than necessary to deal with the effect of lagged states. The following general structure will work:
source markov.src
compute n=3
dec rect p(n-1,n)
dec vect f(n) pstar(n)
nonlin(parmset=markovparms) p
nonlin(parmset=regparms) .....
* initialize the p's and the regression parameters
frml markov = f=SimpleRegimeF(t),$
pstar=%msupdate(f,%mcstate(p,pstar),fpt),log(fpt)
maximize(parmset=markovparms+regparms,start=(pstar=%mcergodic(p))) markov start end
All you need is to write a function to do the likelihoods for each branch:
function simpleregimef time
type vector simpleregimef
type integer time
dim simpleregimef(3)
* instructions for computing likelihoods (not log likelihoods) of the three branches
* at entry <<time>>
See, for instance, the SWARCH example.
Re: Markov model
Posted: Thu Sep 30, 2010 5:23 pm
by terrya
Re: Markov model
Posted: Thu Mar 10, 2011 6:53 pm
by billmil
Does anyone know about implementing the new Filardo procedure for estimating an MS model with time-varying probabilities? I have version 8 of RATS, and I follow all of the commands in Filardo, but I get an error message about missing operands. In particular, I do the following:
compute nlags=4
source msvarsetup.src
compute gstart=1948:6,gend=1992:8
@MSVARSetup(lags=nlags)
# g
dec equation p1eq p2eq
dec vector v1 v2
nonlin(parmset=tv) v1 v2
function %MSVARPmat time
type rect %MSVARPmat
type int time
local integer i j
local rect pexpand
local real z
compute %MSVARInitTransition()
if nexpand==nstates {
compute %MSVARPmat=pexpand*p
ewise
## SX16. Missing Operand or Adjacent Operators
>>>> ewise<<<<
I am not sure what I am doing wrong.
Re: Markov model
Posted: Thu Mar 10, 2011 8:19 pm
You're missing the rest of that last EWISE instruction. If you have code that was sent through an e-mail, it might have wrapped the rest of the line down to the next line. It probably should be reading:
