Specific shock: Impulse Response Functions
Posted: Mon Dec 20, 2010 7:46 pm
Say for instance I have a near-VAR estimated using Seemingly Unrelated Regressions, I group the 11 equations into a system called VAR11 and then I use a non-recursive factorisation of the covariance matrix.
The problem I have is that I want to get a specific shock of 0.25 to the interest rate variable. I am aware that I can simply take ALL the system variable responses and rescale them to make the first period std deviation shock of the interest rate into the size that i want it. for instance if i get a 0.50 interest rate standard deviation shock. dividing ALL system variable responses by 2 will rescale the shock and the system variable impulse responses. This is possible since it's a liner combination.
However, I want to be able to do this in RATS. So I tried changing the shock vector using the "impulse" instruction. but the output i get shows that ALL the first period responses change. Am I using it correctly? My understanding from the manual was that changing the shock vector would result in a specific shock to ONE variable?
impulse(model=var11,shock=||0, 0, 0, 0, 0, 0, 0, 0, 0, 0.25, 0||,results=responses,factor=fsvar,steps=20,windom="IRFs")
I get the following:
Entry LUSGDP LCOMP LC LINVST LG LEX LIM INFLYTM LM1 INT LRTWI
1 0 0 0.0000000 0.0000000 0.0000000 0.0000000 0.0000000 0.0000000 0.0000000 0.2500000 0.0000000
2 0 0 -0.0009482 0.0006517 -0.0004229 -0.0003984 0.0037476 0.0141736 -0.0002462 0.1751326 0.0062548
as you can see all the first period responses have changed! I want ONLY the INT (cashrate) shock to be 0.25 and others to react the usual way it would for a standard deviation shock of INT (0.287) which is:
Responses to Shock in INT
1 0.0000000 0.00000000 0.0000000 0.0000000 0.0000000 0.0000000 0.0000000 0.0000000 -0.0025720 0.2871684 0.0189749
2 0.0000000 0.00000000 -0.0004174 0.0006019 -0.0001925 0.0017265 0.0092522 -0.0166038 -0.0012682 0.2658186 0.0220225
Also, i tried to specify the coloumn which is shocked and that command does not seem to work. I get ALL shocks and ALL responses, where as I ONLY want the output to give me the INT Shock's impulse response. So I tried "column=10" and it still gives me ALL the output.
Any help would be most appreciated.
cheers
Mj
cheers
Mj
