Calibration of forecast means
Posted: Fri Jan 28, 2011 1:26 pm
by apollon
Hi
Is it possible to calibrate the forecast means to observed future quotes in a VAR model ?
I'm thinking that since E(y(t)) = mean, we could instead have a term structure of mean(t)
calibrated from futures on y(t) where available, such as S&P futures. Can we do that in RATS ?
thanks
Apollon
Re: Calibration of forecast means
Posted: Fri Jan 28, 2011 2:02 pm
Look at the section on conditional forecasting in the User's Guide. That sounds like it's exactly what you want.
Posted: Fri Jan 28, 2011 2:30 pm
by apollon
Hi Tom
I am not looking to fix the values in advance, so I still want to keep the volatility around the mean.
Is it possible to only fix the mean ?
Posted: Fri Jan 28, 2011 4:36 pm
Conditional forecasting will give you a set of shocks which give you the mean that you want. Any mean zero noise added to those will maintain that mean. What the appropriate noise variance would be is unclear, since fixing the mean of the process is too vague a restriction to allow computing a restricted distribution for the shocks.
Posted: Mon Jan 31, 2011 2:06 pm
by apollon
Hi Tom
Assuming we are calculating base (not conditional) forecasts, can we not modify the expectations as below:
E(y(t+1)) = v(t+1) + A(1)y(t) + ... + A(p)y(t-p+1)
E(y(t+2)) = v(t+2) + A(1)y(t+1) + ... + A(p)y(t-p+2)
For a VAR(1) process, instead of getting the below forecast:
E(y(t+h)) = [I(k) + A(1) + ... + A(1)^(h-1)]v + A(1)^h*y(t)
we would get:
E(y(t+h)) = v(t+1) + ... + v(t+h) + ... + A(1)[y(t) + y(t+1) + ...] + ... + A(p)[y(t) + y(t+1) + ...]
The distributions are still normal with same volatilities and correlations but a time dependent mean.
In other words, we would take the results from the forecast instruction and add or subtract a constant
at a particular timestep of interest. We would do the same when calculating forecast intervals. In that case:
y(t+h) - y(t)(h) ~ N[v(t+h)-v(t), sigma(y)(h)] so that [y(t+h) - y(t)(h) - (v(t+h)-v(t))] / sigma(k)(h) ~ N(0,1)
Doesn't this make (some) sense ? Thanks.
