BVARSELECTION - Korobilis (2011)
jonasdovern
Unread post by jonasdovern »
I coded the approach for Bayesian variable selection in VAR models as proposed by Korobilis, D. (2011), VAR Forecasting Using Bayesian Variable Selection, Journal of Applied Econometrics, forthcoming. This is what I would call a beta version. If you have any hints on bugs or ways to improve the efficiency of the code, please feel free to publish them here. In particular, I wonder whether the gibbs sampler could be speed up a little bit as it becomes very slow for VARs of more than 4 or 5 variables. (I think the key line that slows down is the one where beta is computed during each iteration (comp beta_var = inv(D0_inv+tr(x_star)*V*x_star) which involves inverting a huge matrix.)
* This procedure allows the estimation of Bayesian VAR models with variable selection as outlined in Korobilis, D. (2011),
* VAR Forecasting Using Bayesian Variable Selection, Journal of Applied Econometrics, forthcoming.
*	@BVARSELECTION( options ) start end forecasts
*	# varlist
*	# detlist
*	start end 	- first and last period of estimation period
*	forecasts		- (optional) vector of series with point forecasts basedn on the restricted B-VAR
*	varlist		- list of variables of the VAR
*	detlist		- list of exogenous variables in the VAR
*	OPTIONS:
*	  lags [1]		- lag order of VAR
*	  nburns [1000]	- number of initial convergence iterations for Gibbs sampler
*	  ndraws [1000]	- number of iterations for Gibbs sampler
*	  ftime			- forecasting time
*	  fsteps [12]		- number of forecast steps
*	  [report]/noreport	- determines if results are displayed
*	  graph/[nograph] 	- determines if forecasts are plotted
*	  bprior [not used]	- provides values for prior means for the model coefficients (ord. like with RATS-VAR)
*	  gprior [.5]		- prior for probability of inclusion of parameters
*	  rlprior [9.]		- prior for lambda corresponding to coefficients of VAR lags (with ridge prior)
*	  rldetprior [100.]	- prior for lambda corresponding to coefficients of exogenous variables (with ridge prior)
*	  mlprior [.1]		- prior for lambda (with Minnesota prior)
*	Written by Jonas Dovern (based on Matlab codes by D. Korobilis),
*	Kiel Economics Research & Forecasting GmbH & Co. KG (www.kieleconomics.de),
*	v0.9 - 11/2011.
source(noecho) mcmcpostproc.src
procedure BVARSELECTION start end forecasts
	type integer  start end
	type vec[ser] *forecasts
	option integer lags 1
	option integer nburns 1000
	option integer ndraws 1000
	option integer ftime
	option integer fsteps 12
	option switch  report 1
	option switch  graph 0
	option choice  prior 1 ridge minnesota
	option vec	     bprior
	option real	     gprior .5
	option real	     rlprior 9.
	option real	     rldetprior 100.
	option real	     mlprior .1
	local integer  nvar ndet i j l draw periods hfi vfi lftime
	local real     p_j_tilde c d
	local index    varlist detlist
	local rec      x y x2 y2 D0 D0_inv eta eta_inv beta_OLS2 sse sigma V x_star beta_var beta2 theta2
	local rec[int] dettable
	local vec		b0 p_j gamma beta_OLS beta ux theta theta_star theta_star_star beta_mean beta_stderrs gamma_mean theta_mean theta_cd uni_var
	local vec[ser] fc_ols simfc fc_gibbs
	local ser[vec] beta_draws gamma_draws theta_draws
	local ser[rec] sigma_draws
	local ser[int] permutation
	local model	VARmodel
	local vec[str] rowlabels
	*** Read varialbes and deterministic components from cards
	enter(varying,entries=nvar) varlist
	linreg(noprint) varlist(1)
	comp detlist = %reglist(), dettable = %tablefromrl(detlist), ndet=%nreg
	*** Check data availability and set forecasting time
	inquire(regressorlist) i j
	# varlist
	if i>start-lags.or.j<end {
		disp "There are missing data points in the sample you specified for the estimation!"
		disp "(Pay attention to lags!)"
		return
	if %defined(bprior).and.%rows(bprior)<>lags*nvar*nvar+nvar*ndet {
		disp "You provided a prior for beta (bprior) which does not have the right number of elements!"
		return
	comp lftime = %if(%defined(ftime),ftime,end+1)
	*** Define model and produce OLS forecasts
	system(model=VARmodel)
		variables varlist
		lags 1 to lags
		det detlist
	estimate(noprint) start end
	forecast(noprint,model=VARmodel,nostatic,from=lftime,steps=fsteps,results=fc_ols)
	*** Construct data matrices
	dim y2(end-start+1,nvar) x2(end-start+1,nvar*lags+ndet)
	ewise y2(i,j) = ([series] varlist(j))(start-1+i)
	comp y = %vec(y2)
	do i=start,end
		do j=1,nvar
			do l=1,lags
				comp x2(i-start+1,(j-1)*lags+l) = ([series] varlist(j))(i-l)
			end do l
		do j=1,ndet
			comp x2(i-start+1,nvar*lags+j) = ([series] dettable(1,j))(i-dettable(2,j))
	comp x = %kroneker(%identity(nvar),x2)
	*** Set up arrays to hold the simulated parameters
	gset beta_draws  1 ndraws = %zeros(lags*nvar*nvar+nvar*ndet,1)
	gset gamma_draws 1 ndraws = %zeros(lags*nvar*nvar+nvar*ndet,1)
	gset theta_draws 1 ndraws = %zeros(lags*nvar*nvar+nvar*ndet,1)
	gset sigma_draws 1 ndraws = %zeros(nvar,nvar)
	*** Define priors
	if %defined(bprior)
		comp b0 = bprior; * prior mean of beta
	else {
		if prior==1.or.prior==3
			comp b0 = %zeros(lags*nvar*nvar+nvar*ndet,1)
		else if prior==2 {
			ewise b0(i) = %if(%clock(i,lags*nvar+ndet)==1,1.,.0)
	comp D0 = %identity(lags*nvar*nvar+nvar*ndet); * prior precision of beta
	if prior==1
		ewise D0(i,j) = D0(i,j)*%if(%clock(i,lags*nvar+ndet)<=lags*nvar,rlprior,rldetprior)
	else if prior==2 {
		* Getting error variance from univariate models
		dim uni_var(nvar)
		do k=1,nvar
			linreg(noprint) varlist(k) start end
			# constant varlist(k){1 to lags}
			comp uni_var(k) = %SEESQ
		end do k
		* Filling prior matrix
		do i=1,nvar
			do j=1,lags*nvar+ndet
				if %clock(j,lags*nvar+ndet)>lags*nvar
					comp D0((i-1)*(lags*nvar+ndet)+j,(i-1)*(lags*nvar+ndet)+j) = D0((i-1)*(lags*nvar+ndet)+j,(i-1)*(lags*nvar+ndet)+j)*100*uni_var(i)
				else if j>(i-1)*lags.and.j<=i*lags
					comp D0((i-1)*(lags*nvar+ndet)+j,(i-1)*(lags*nvar+ndet)+j) = D0((i-1)*(lags*nvar+ndet)+j,(i-1)*(lags*nvar+ndet)+j)*%clock(j,lags)^2
				else
					comp D0((i-1)*(lags*nvar+ndet)+j,(i-1)*(lags*nvar+ndet)+j) = D0((i-1)*(lags*nvar+ndet)+j,(i-1)*(lags*nvar+ndet)+j)*(mlprior/%clock(j,lags)^2)*(uni_var(i)/uni_var(fix((j-1)/lags)+1))
	comp D0_inv = inv(D0)
	comp p_j = gprior*%ones(lags*nvar*nvar+nvar*ndet,1); * prior probability for inclusion of parameter
	comp eta = %identity(nvar)
	comp eta_inv = inv(eta)
	*** Initialize parameters
	comp gamma = %ones(lags*nvar*nvar+nvar*ndet,1)
	comp beta_OLS  = inv(tr(x)*x)*tr(x)*y
	comp beta_OLS2 = inv(tr(x2)*x2)*tr(x2)*y2
	comp sse       = tr(y2-x2*beta_OLS2)*(y2-x2*beta_OLS2)
	comp sigma     = sse/((end-start+1)-lags*nvar-1)
	dim ux(lags*nvar*nvar+nvar*ndet)
	dim fc_gibbs(nvar)
	*** Running Gibbs sampler
	infobox(action=define,progress,lower=-nburns,upper=ndraws) "Running Gibbs sampler"
	do draw=-nburns,ndraws
		infobox(action=modify,current=draw)
		comp V      = %kroneker(inv(sigma),%identity(end-start+1))
		comp x_star = %ones((end-start+1)*nvar,1)*tr(gamma).*x
		*** Update beta
		comp beta     = beta_var*(D0*b0+tr(x_star)*V*y) + %decomp(beta_var)*(ux=%ran(1.0))
		comp beta2    = %vectorect(beta,lags*nvar+ndet)
		*** Update gamma
		boot(noreplace) permutation 1 lags*nvar*nvar+nvar*ndet 1 lags*nvar*nvar+nvar*ndet
		do i=1,lags*nvar*nvar+nvar*ndet
			comp theta                           = beta.*gamma
			comp theta_star                      = theta
			comp theta_star_star                 = theta
			comp theta_star(permutation(i))      = beta(permutation(i))
			comp theta_star_star(permutation(i)) = .0
			comp c         = p_j(permutation(i))*exp(%scalar(-gprior*tr(y-x*theta_star)*V*(y-x*theta_star)))
			comp d         = (1-p_j(permutation(i)))*exp(%scalar(-gprior*tr(y-x*theta_star_star)*V*(y-x*theta_star_star)))
			comp p_j_tilde = c/(c+d)
			comp gamma(permutation(i)) = %ranbernoulli(p_j_tilde)
		comp gamma2 = %vectorect(gamma,lags*nvar+ndet)
		comp theta2 = beta2.*gamma2
		*** Update sigma
		comp sigma = %ranwisharti(%decomp(inv(eta_inv+tr(y2-x2*theta2)*(y2-x2*theta2))),end-start+1-(lags*nvar+ndet))
		*** Save draws and make forecasts
		if draw>0 {
			*** Save draws
			comp beta_draws(draw)  = beta
			comp gamma_draws(draw) = gamma
			comp theta_draws(draw) = theta
			comp sigma_draws(draw) = sigma
			*** Make forecasts
			comp %modelsetcoeffs(VARmodel,theta2)
			simulate(model=VARmodel,cv=sigma,results=simfc,from=lftime,steps=fsteps)
			do i=1,nvar
				set fc_gibbs(i) lftime lftime+fsteps-1 = %if(draw==1,simfc(i)(t),fc_gibbs(i)(t)+simfc(i)(t))
	end do draw
	infobox(action=remove)
	*** Post simulation processing
	if report {
		do i=1,nvar
			set fc_gibbs(i) lftime lftime+fsteps-1 = fc_gibbs(i)/ndraws
		@MCMCPostProc(ndraws=ndraws,mean=theta_mean,cd=theta_cd) theta_draws
		@MCMCPostProc(ndraws=ndraws,mean=beta_mean,stderrs=beta_stderrs) beta_draws
		@MCMCPostProc(ndraws=ndraws,mean=gamma_mean) gamma_draws
	*** Report output
	if report {
		dim rowlabels(lags*nvar*nvar+nvar*ndet)
		do k=1,nvar
			do j=1,nvar
				do l=1,lags
					comp rowlabels((k-1)*(lags*nvar+ndet)+(j-1)*lags+l) = %if(j==1.and.l==1,%l(varlist(k))+"_"+%l(varlist(j))+"{"+%string(l)+"}","   "+%l(varlist(j))+"{"+%string(l)+"}")
				end do l
			do j=1,ndet
				comp rowlabels((k-1)*(lags*nvar+ndet)+nvar*lags+j) = "    "+%l(dettable(1,j))+"{"+%string(dettable(2,j))+"}"
		end do k
		disp; disp "BVAR has been estimated over the period" %datelabel(start) "-" %datelabel(end) "."
		report(action=define,vlabels=rowlabels,hlabels=||"","OLS-Beta","Beta*","Stderrs","Gamma**","Theta***","Geweke CD****"||)
		report(action=modify,fillby=columns,atrow=1,atcol=2) beta_OLS
		report(action=modify,fillby=columns,atrow=1,atcol=3) beta_mean
		report(action=modify,fillby=columns,atrow=1,atcol=4) beta_stderrs
		report(action=modify,fillby=columns,atrow=1,atcol=5) gamma_mean
		report(action=modify,fillby=columns,atrow=1,atcol=6) theta_mean
		report(action=modify,fillby=columns,atrow=1,atcol=7) theta_cd
		report(action=format,picture="*.##")
		report(action=show,title="Outputs from Gibbs sampler")
		disp "*    Mean of posterior density of beta."
		disp "**   Average posterior probability of the restiction index."
		disp "***  Mean of posterior density of beta*gamma."
		disp "**** Geweke CD for theta."
	*** Plot forecasts
	if graph {
		inquire(seasonal) periods
		@sethfiandvfi(number=nvar,hfi=hfi,vfi=vfi)
		spgraph(hfi=hfi,vfi=vfi)
			do k=1,nvar
				graph(header=%l(varlist(k)),key=upleft,klabels=||"Data","OLS","Restr. B-VAR"||) 3
				# varlist(k) %imax(start,end-periods*3) end; # fc_ols(k) lftime lftime+fsteps-1; # fc_gibbs(k) lftime lftime+fsteps-1
			end do k
	*** Return variables if requested
	if %defined(forecasts) {
		dim forecasts(nvar)
		do k=1,nvar
			set forecasts(k) lftime lftime+fsteps-1 = fc_gibbs(k)(t)
		end do k
end procedure BVARSELECTION
April86
Re: BVARSELECTION - Korobilis (2011)
Unread post by April86 »
Hi Jonas,
I think we need "mcmcpostproc.src" file to run the RATS program you posted. Could you please make it available? Thanks.
April
That's a standard RATS procedure. You should be able to just take the source instruction out.
April86
Thanks. I will try to run it.
April
April86
Dear all,
When I tried to run the posted RATS code, the following error message showed up:
## SX11. Identifier %RANBERNOULLI is Not Recognizable. Incorrect Option Field or Parameter Order?
>>>>)) = %ranbernoulli(<<<<
Common errors are
How can I load the actual data and get the program running? Thanks.
April
April86
I replaced "%ranbernoulli" with "%ranbranch" in the source procedure BVARSELECTION. However, I got the following error message:
## CP18. SETHFIANDVFI is not the Name of a PROCEDURE. (Did you forget to SOURCE?)
>>>> @sethfiandvfi(<<<<
It does not seem to be a standard RATS procedure. How can I debug this program?
April
jonasdovern
Dear April,
this is only needed when plotting results. It is a little procedure I wrote to determine the appropriate number of columns and rows in the plot. I wasn't aware that I did not post it. Here it is:
PROCEDURE SETHFIANDVFI
	option integer	number
	option integer	*hfi
	option integer	*vfi
	if number<=2
		comp vfi=1
	else if number<=6
		comp vfi=2
	else if number<=12
		comp vfi=3
	else if number<=16
		comp vfi=4
	else if number<=25
		comp vfi=5
	else
		return
	if number<=1
		comp hfi=1
	else if number<=4
		comp hfi=2
	else if number<=9
		comp hfi=3
	else if number<=20
		comp hfi=4
	else if number<=25
		comp hfi=5
	else
		return
END PROCEDURE
April86
I see. Thanks.
April
