PANELCAUSE.RPF—Granger causality in panel data
PANELCAUSE.RPF is an example of a test for (Granger) causality in a panel data set allowing for heterogeneity in the coefficients and variances.
Detailed description
panelmoney.xls
Data file
(58 KiB) Downloaded 913 times
Ozmando
Re: PANELCAUSE.RPF—Granger causality in panel data
Unread post by Ozmando »
TomDoan wrote:PANELCAUSE.RPF does a test for Granger causality in a heterogeneous panel.
panelmoney.xls
Is this test applicable if one want to check for long run causality? please?
oz
No. Long-run causality is a test just on the loadings in a VECM. This is a test on all lags in a VAR.
Last bumped by TomDoan on Tue Dec 03, 2024 4:49 pm.
