I am reading Chap7 Enders(2010) AETS 3rdEdn and have attempted to replicate Rothman's (1998) results p.433 & p.445 (they are not in the example's provided with Enders(2014) AETS 4thEdn).
cal(q) 1948:1
data(format=fred) 1948:1 1979:4 unrate
set lunrate = log(unrate)
* stationarity tests
@dfunit(ttest,det=trend) lunrate
@dfunit(ttest,det=trend,maxlags=6,method=gtos) lunrate
@dfunit(ttest,det=trend,maxlags=6,method=aic) lunrate
* detrend lunrate
set trend = t
set trend2 = trend^2
set trend3 = trend^3
linreg(define=detrend) lunrate / resids
# constant trend trend2 trend3
prj fitted
set detrendedlun = lunrate - fitted
prin / lunrate fitted resids detrendedlun
graph(hea='Rothman (1998) U.S. unemployment rate',key=upleft, $
klabels=||"lunrate","fitted","detrendedlun"||) 3
# lunrate
# fitted
# detrendedlun
@dfunit(ttest) detrendedlun
@dfunit(ttest,maxlags=6,method=gtos) detrendedlun
@dfunit(ttest,maxlags=6,method=aic) detrendedlun
* AR model
linreg(define=AR) detrendedlun
# detrendedlun{1 to 2}
* GAR model
set detrendedlun3 = detrendedlun^3
linreg(define=GAR) detrendedlun
# detrendedlun{1 to 2} detrendedlun3{2}
* BL model
dec series eps
clear(zeros) eps
nonlin alpha beta gamma
frml bilinear detrendedlun = z = alpha*detrendedlun{1}+beta*detrendedlun{2}+gamma*detrendedlun{1}*eps{3},eps=detrendedlun-z,z
* estimate ARMA model
nonlin alpha beta gamma=0.0
nlls(frml=bilinear) detrendedlun 1948:3 1979:4
* estimate bilinear model
* SETAR model
set thresh1 = detrendedlun{1}; * use delay of 1
@ThreshTest(trim=.15,thresh=thresh1,nograph) detrendedlun 1948:1 *
# constant detrendedlun{1 to 2}
disp "breakvalue" %%breakvalue
disp "Sum of Squared Residuals" %rss
* Rothmans's breakvalue
*comp %%breakvalue = 0.062
* Estimate the two branches of the model.
linreg(smpl=thresh1>=%%breakvalue) detrendedlun 1948:1 *
linreg(smpl=thresh1<%%breakvalue) detrendedlun 1948:1 *
2. How has Rothman detrended the U.S. unemployment rate?
3. For the Bilinear model, there are less data points in the estimation 84pts vs. 126pts. Why? However, If I change eps{3} to e.g. eps{2} in the interaction term I have the correct 126pts.
4. For the SETAR model the breakvalue is different, presumably as to the data.
5. Let's say I generate multi-step ahead OOS forecasts and produce a fan-chart, as below for the detrended log-unrate. Using these results I want to generate a fan chart for the trended & unlogged forecasts and similarly for the prediction intervals i.e. I would like to convert all the results in the fan-chart into LEVELS. So something like restore the trend and exp the log-levels forecasts i.e. get "un" forecasts, then exp the RHS of each prediction interval equation with "un" forecast instead of rfore. Is this correct? and if so how in RATS?
* Fan chart for detrended log-unrate
* detrend lunrate
set trend 1948:1 1982:4 = t
set trend2 1948:1 1982:4 = trend^2
set trend3 1948:1 1982:4 = trend^3
prj fitted
boxjenk(ar=2,diffs=0,ma=0,define=req) detrendedlun 1948:1 1979:4
uforecast(equation=req,stderrs=stderrs) rfore 1980:1 1982:4
prin / lunrate fitted resids detrendedlun rfore
set lower95 1980:1 1982:4 = rfore+%invnormal(.025)*stderrs
set upper95 1980:1 1982:4 = rfore+%invnormal(.975)*stderrs
set lower80 1980:1 1982:4 = rfore+%invnormal(.1)*stderrs
set upper80 1980:1 1982:4 = rfore+%invnormal(.9)*stderrs
graph(footer="Forecasts and Prediction Intervals",ovcount=4,overlay=fan,ovsame) 6
# detrendedlun 1948:1 1979:4
# rfore
# lower95
# lower80
# upper80
# upper95
many thanks,
Amarjit
