Can I solve a nonlinear equation by Rats?
Dear all,
Can I solve a nonlinear equation for X like the below without reducing it by hands ?
X = a + sqrt(X+b)
The equation I have to solve is more complex, thus I do not want to compute its reduced form.
(I am not good at GAUSS or MATLAB. I am happy if RATS can do it!)
Any comment are welcome.
X = a + sqrt(X+b)
Re: Can I solve a nonlinear equation by Rats?
Thank you so much for your prompt reply.
This is the first time I know about FIND instruction.
Could you teach me two more questions?
(1) Actually, what I have to solve is like the following system for Z.
X*(a+X)^(1/3) = Y*(a+Y)^(1/3)
X = b - Z
Y = c + Z
Can I obtain the solution for Z WITHOUT substituting the 2nd and 3rd equations to X and Y in the 1st?
(2) How about a simultaneous system for U and V like:
U = sqrt(Y)
X = U - V
Y = c + V
Thanking in advance for your trouble.
X = b - Z
Y = c + Z
U = sqrt(Y)
X = U - V
Y = c + V
First, you want to make sure that you write the exponent so 1/3 isn't an integer divide. FIND can do intermediate calculations, so:
compute a=3.0,b=5.0,c=2.0,x=0.0,y=0.0,z=2.0
nonlin z
find root X*(a+X)^(1.0/3)-(Y*(a+Y)^(1.0/3))
comp X = b - Z
comp Y = c + Z
end find
The simultaneous equation is a bit harder, as you have to create a joint expression and minimize it. (FIND ROOT actually minimizes the absolute value of the expression you put in).
nonlin u v
find min abs(X*(a+X)^(1./3)-(Y*(a+Y)^(1./3)))+abs(U-sqrt(Y))
comp X = U - V
comp Y = c + V
end find
nonlin z
comp X = b - Z
comp Y = c + Z
end find
nonlin u v
comp X = U - V
comp Y = c + V
end find
p.s.
One more question.
What I am doing now is simply computing the optimal bond holding in the Euler equation though its tax system is a bit complicated.
I wrote the code below ( by substituting budget constraints, reduced form of consumption, etc.), but I can not obtain any output (no error message as well).
Could you teach me the reason if possible?
Again, thanking in advance.
compute Y0 = 1
compute Y1 = Y0
compute Y2 = Y0
compute lamda = 1
compute delta = 0.3
compute R = 1.2
compute G = 0.2
compute rho = 0.1
compute alpha = 0.5
nonlin B
find(print) root ((1-((G-B)/Y1)-((lamda/2)*(((1/lamda)*(1-sqrt(1-2*lamda*((G-B)/Y1))))**2)))*Y1)**R $
/((1-(((1+rho)*B+G)/Y2)-((lamda/2)*(((1/lamda)*(1-sqrt(1-2*lamda*(((1+rho)*B+G)/Y2))))**2)))*Y2)**R $
= (1+(lamda*((1/lamda)*(1-sqrt(1-2*lamda*((G-B)/Y1))))/sqrt(1-2*lamda*((G-B)/Y1)))) $
/(1+(lamda*((1/lamda)*(1-sqrt(1-2*lamda*(((1+rho)*B+G)/Y2))))/sqrt(1-2*lamda*(((1+rho)*B+G)/Y2))))
One more question.
compute Y0 = 1
compute Y1 = Y0
compute Y2 = Y0
compute lamda = 1
compute delta = 0.3
compute R = 1.2
compute G = 0.2
compute rho = 0.1
compute alpha = 0.5
nonlin B
Thank you so much for your SO prompt reply.
Please ignore my previous post.
I think I am going to reach the goal.
This is my code.
compute Y0 = 1.0
compute Y1 = Y0
compute Y2 = Y0
compute delta = 0.3
compute R = 1.2
compute G = 0.2
compute rho = 0.1
compute alpha = 0.5
nonlin B
find root (c1/c2)^R = (1+d_gamma_2)/(1+d_gamma_1)
compute xi_1 = (G-B)/Y1
compute xi_2 = ((1+rho)*B+G)/Y2
compute t1 = (1/lamda)*(1-sqrt(1.0-2.0*lamda*xi_1))
compute t2 = (1/lamda)*(1-sqrt(1.0-2.0*lamda*xi_2))
compute gamma_1 = (lamda/2)*(t1**2)
compute gamma_2 = (lamda/2)*(t2**2)
compute d_gamma_1 = lamda*t1/sqrt(1.0-2.0*lamda*xi_1)
compute d_gamma_2 = lamda*t2/sqrt(1.0-2.0*lamda*xi_2)
compute c1 = (1-xi_1-gamma_1)*Y1
compute c2 = (1-xi_2-gamma_2)*Y2
end find
Bu i got the following message:
## SX11. Identifier C1 is Not Recognizable. Incorrect Option Field or Parameter Order?
>>>>find root (c1/c<<<<
Is it possible you meant
Y1
Common errors are
* a missing $ at the end of a long line which continues to the next
Could you teach me why?
I really appreciate your kindness.
This is my code.
compute Y0 = 1.0
compute Y1 = Y0
compute Y2 = Y0
compute delta = 0.3
compute R = 1.2
compute G = 0.2
compute rho = 0.1
compute alpha = 0.5
nonlin B
end find
>>>>find root (c1/c<<<<
Y1
Common errors are
Because you never defined C1 (or C2). That's what the message is telling you.
Thank you for your reply.
at the end of Find-End loop.
Do you mean the order of my code is wrong?
Or, simply I should add,
compute C1 = 0.0
compute C2 = 0.0
before FIND ?
compute C1 = 0.0
compute C2 = 0.0
before FIND ?
Thanks to your warm kindness, I finally obtain the solution.
My collections are as follows.
(1) I simply add
compute C1 = 1.0
etc..
(2) I modify
to
compute gamma_2 = (lamda/2)*(t2^2.0)
Again, I deeply appreciate your kindness.
Sincerely,
(1) I simply add
compute C1 = 1.0
etc..
(2) I modify
to
Sincerely,
Thank you for your kind suggestion yesterday.
Unfortunately, I face the next priblem.
I am now computeing a simple optimal borrowing problem of a governmnet with 2 period, CES utirity, like:
compute Y1=1.0, Y2=1.0
nonlin B
find max (1/1-R)*c1^(1-R)+(1/(1+r))*(1/1-R)*c2^(1-R)
compute T_1 = G - B
compute T_2 = (1+r)*B + G
compute c1 = Y1-T_1
compute c2 = Y2-T_2
end find
As the results, I can get B=0.
However, B<>0 when I use the Euler quation like:
nonlin B
find root (c2/c1)^R = 1
compute T_1 = G - B
compute c1 = Y1-T_1
compute c2 = Y2-T_2
end find
The result is:
Variable Coeff
1. B 0.7272753906
Could you teach me what I mistake?
nonlin B
compute T_1 = G - B
compute c1 = Y1-T_1
compute c2 = Y2-T_2
end find
nonlin B
compute T_1 = G - B
compute c1 = Y1-T_1
compute c2 = Y2-T_2
end find
The result is:
Variable Coeff
1. B 0.7272753906
should be
find root (c2/c1)^R-1
should be
It seems that I need a bit more time to use FIND well....
Anyway, thank you so much for your kind assistance!
Sincerely,
Sincerely,
I'm terribly sorry to bother you over and over again.
Could you teach me if it is possible to maximize a expected value like below ?
max log(C1) + S log(C2+e) f(e) de
s.t. C1 + 0.9*C2 = 1 where e ~ uniform(-1.0, 1.0).
( "S" above means integral here.)
Yours Sincerely.
Yours Sincerely.
You would have to use FIND MAX and use quadrature to approximate the integral (such as with the %ISIMPSON function).
Thank you so much for your comments on December 19, 2017.
I am still working on this topic.
This time, I attach my code. My question is simple, but let me first explain what I am doing.
On this code:
The attached is a code to replicate Aizenman et al (2000) which investigates a relationship between an income shock and an optimal level of the government
bond issues. They consider a simple two-period setting where an income shock in period 2 is uncertain between [-limit, limit].
As is well-known, if we have a negative income shock in period 1, the government will issue their bonds for consumption smoothing. However, in this model, the borrowing constraint is set depending on tax revenue in period 2 which in turn depends on the expected income shocks in period 2. Therefore, they may unable to accomplish their optimization perfectly. In a polar case, their bond issue will be fixed at a certain level.The attached code is to depict the situation above. When you run it, you can see the figure the bond issue is restricted at a certain level.
My question:
Let me turn to my question. The revenue in period 2 depends on tax efficiency parameter lambda as well. When lambda is, for example, 1.1, this code exactly replicates Aizenman (2000). However, when lambda = 1.55, we see weird horizontal part of the graph which is not emerged in Aizenman (2000) (Run my code, please). Actually, when I changed the method from Simplex to, for example, to generic, I have a different figure again. Thus, I expect the reason why I got the different figure from Aizenman (2000) is my inferior technique for Rats.
So, could you tell me if you have any idea?
thanking in advance for your trouble. I am looking forward to your assistance.
Reference:
Joshua Aizenman, Michael Gavin & Ricardo Hausmann (2000) Optimal tax and debt policy with endogenously imperfect creditworthiness, The Journal of International Trade & Economic Development, 9:4, 367-395, DOI: 10.1080/096381900750056830
To link to this article:
https://doi.org/10.1080/096381900750056830
On this code:
My question:
Reference:
- Inquiry.RPF
- (5.56 KiB) Downloaded 1030 times
