Extreme Value Theory (EVT): Hill estimator
ac_1
Unread post by ac_1 »
Here's my loop for risk algo Historical Simulation (HS), calculate VaR and ES:
do i = 1, %allocend() - WIN
   clear dlp1
   clear y
   set dlp1 1+i WIN+i = dlp
   order(index=ix,nodecreasing) dlp1 1+i WIN+i
   set y 1+i WIN+i = dlp1(ix)
   comp op = fix(WIN*alpha)+i; * alpha smallest
   comp VaR = - y(op) * SCALE
   sstats(mean) 1+i fix(WIN*alpha)+i y>>mu
   comp ES = - mu * SCALE
   comp VaR_1(WIN+1+i) = VaR
   comp ES_1(WIN+1+i) = ES
   disp 'obs' WIN+i+1 'HS 1% VaR=' VaR 'HS 1% ES=' ES
I ought to get a similar picture of multi-step ahead forecasts (sqrt-of-time) for Extreme Value Theory (EVT): Hill estimator, even though HS and EVT are completely different methods.
How would I implement EVT in RATS?
Amarjit
Re: Extreme Value Theory (EVT): Hill estimator
Tsay's book has a whole chapter (Chapter 7) on that. There are four examples in the textbook examples.
ac_1
Thanks! Based on the HS loop (fixed rolling window) and using @HillGEV, it would be something like the following, however what are the formulae for VaR and ES as positive numbers?
comp WIN = 1000
comp SCALE = 100.0
comp CT = 100; * threshold for tail observations
   clear dlp1
   clear y
   clear ysort
   set y 1+i WIN+i = -dlp1
   order(index=ix,nodecreasing) y 1+i WIN+i
   set ysort 1+i WIN+i = y(ix)
   @HillGEV(span=CT,tail=left) ysort 1+i WIN+i
   sstat 1+i i+CT %%hill>>sumlog
   comp iota = -(CT/sumlog)
   if iota <= 1.0 {
      comp VaR_EVT = %NA
      comp ES_EVT  = %NA
   comp threshold = ysort(i+CT+1) * SCALE
   comp VaR_EVT = ?
   comp ES_EVT  = ?
   comp VaR_1(WIN+1+i) = VaR_EVT
   comp ES_1(WIN+1+i)  = ES_EVT
   disp 'obs' WIN+i+1 'EVT iota=' iota 'VaR=' VaR_EVT 'ES=' ES_EVT
Although, @HillGEV is designed for GEV asymptotics, not classical Pareto Hill estimator:
1/ihat = (1/k) summation from j=1 to k [log( X(j)/X(k+1))].
I'd like the classical estimator to complement various risk algos.
So, maybe:
set logratios 1+i WE+i = log( ysort / ysort(i+CT+1) )
sstat 1+i i+CT logratios>>sumlog
comp iota = CT / sumlog
comp VaR_EVT = ?
comp ES_EVT  = ?
ac_1 wrote: Mon Jan 19, 2026 1:09 pm Although, @HillGEV is designed for GEV asymptotics, not classical Pareto Hill estimator:
That's what the procedure computes.
ac_1
TomDoan wrote: Tue Jan 20, 2026 8:49 am
Alright if I use
then what are the VaR_EVT and ES_EVT formulae?
  comp VaR_EVT = TSay (2010), p.355, eqn (7.28), if so, how do I extract alphahat, betahat, Xihat from the procedure? Or is there another VaR_EVT formulae?
  comp ES_EVT  = ?
The tail index doesn't provide enough information to compute the VaR and the ES. Those need complete distributions. tsay3p355 does that. The thing to note is that the results are sensitive to the number of extreme values that are included, which is the point of the earlier search.
ac_1
TomDoan wrote: Wed Jan 21, 2026 11:01 am The tail index doesn't provide enough information to compute the VaR and the ES. Those need complete distributions. tsay3p355 does that. The thing to note is that the results are sensitive to the number of extreme values that are included, which is the point of the earlier search.
Are you saying I cannot do a rolling analysis: fixed window T=1000, n=100 (the tail), p=0.01, in each loop, EVT method, and calculate VaR and ES using @HILLGEV, but rather using
nonlin alpha beta k
dec series r
compute alpha=.8,beta=-2.0,k=-.2; * guess values
frml gevmin = %loggevdensity(-r,k,-beta,alpha)
maximize(METHOD=BFGS) gevmin 1 gend
compute var01=%invgev((1-.01)**n,k,-beta,alpha)
I am not certain how to proceed, given my aim: backtest and forecast multi-step ahead VaR and ES using EVT to complement other various risk algos.
Is there a reason you can't put that in a loop?
If you want the ES for a GEV, you will have to find someone who has figured that out.
