header labels
terrya
header labels
Post by terrya »
I want to put a particular set of labels in a header. The labels are different from the variable names. Following the example on graphing impulse response functions in the user guide, I set up the following.
compute varlabels=|| $
    "Australia",$
    "Canada",$
    "France",$
    "Germany",$
    "Italy",$
    "Japan",$
    "NZ",$
    "UK",$
    "USA"||
declare vect[strings] varlabels(9)
compute counter = 0
While counter < 10
{ dofor p = LAUS LCAN LFRA LGER LITA LJAP LNZ LUK LUS
   compute counter = counter + 1
   graph(header = "RGDP per capita: "+varlabels(counter),vlabel="Natural log") 1
  # p
end dofor}
end while
I got the following error message at the declare step.
## SX1. Identifier VARLABELS is Already in use as a(n) RECTANGULAR[STRING]
I can't see how this set-up is different from the IRF example. I've used the dofor instruction instead of the while function in various attempts.
Re: header labels
Do the DECLARE first (you don't have to put a dimension on it). When you do a
compute something=||....||
if RATS hasn't seen <<something>> before, it gets classified as a RECT[type] since that's more general.
terrya
Re: header labels
Post by terrya »
Thanks for quick response. Worked perfectly.
