APBREAKTEST—General test for breaks in linear regression
Re: Structural Break Test
Sounds like you're running a model with quite a few lags. It's possible that the pi option is too small given the size of the data set and size of the model you're running.
Osabuohien247
Unread post by Osabuohien247 »
TomDoan wrote:Sounds like you're running a model with quite a few lags. It's possible that the pi option is too small given the size of the data set and size of the model you're running.
Thank you Tom, i have figured-out what the problem was. It's ok now.
Osabuohien247
Good day everybody,
When the residual dates in Andrews-Quandt and Andrews-Ploberger comes before the Variables (All Coeff) structural break point dates (i.e the robust F-statistics date (1981) before Break point statistics date (1987)),Please what does this denote?
Thank you.
OO
Re: APBREAKTEST—General test for breaks in linear regression
I'm not sure what your question is. @APBREAKTEST with ROBUSTERRORS uses a different test statistic than @APBREAKTEST without it so there is no reason that the two would show the maximum break at the same location.
Last bumped by TomDoan on Mon May 08, 2023 8:32 am.
