You shouldn't have the log(...) there. It's just z=linear function,%cdf(z) for the first and %cdf(-z) for the second.
This is the one part in the EM algorithm that's specific to the logistic probability function. All the other parts of EM are the same since they take the transitions as given. This is simpler with the logistic than it would be with the probit type function. The logistic is simpler for EM, harder for Gibbs sampling and they are a toss-up for straight ML. But they should give very similar results. Since you're not doing Gibbs sampling, why are you using the less used and more complicated of two almost identical ways to handle this.
Appreciate you very much for your help. Now I am writing the code. But when I try to run the markov switching linear model firstly with fixed probability with my program, the mistakes appears as follows.
cal(d) 2006:03:24
open data "D:\Documents and Settings\f_huan\My Documents\mutual fund thesis\one_sample.xls"
data(format=xls,org=cols) 2006:03:24 2012:03:05 apexcess aprm aprmsq
nonlin(parmset=regparms) betas sigsqv
nonlin(parmset=msparms) p
compute gstart=2006:03:24, gend=2012:03:05
@MSRegInitial gstart gend
@MSRegEMGeneralSetup
do emits=1,50
@MSRegEMStep gstart gend
disp "Iteration" emits "Log likelihood" %logl
end do emits
* Polish estimates with 10 iterations of BHHH
compute p=%xsubmat(p,1,nstates-1,1,nstates)
frml logl = f=%MSRegFVec(t),fpt=%MSProb(t,f),log(fpt)
@MSFilterInit
maximize(start=%(%MSRegInitVariances(),pstar=%msinit()),$
parmset=regparms+msparms,$
method=bhhh,iters=10) logl gstart gend
set p1smooth = psmooth(t)(1)
graph(footer="Smoothed Probability of Regime 1",max=1.0,min=0.0)
# p1smooth
The Error Occurred At Location 274, Line 21 of MSREGMSTEP
Called From Location 170, Line 9 of MSREGEMSTEP
Called From Location 68, Line 2 of loop/block
Could you please help me figure it out?
Appreciate you very much for your help. P.S. I am using WINRATS 8.0 version and waiting for my university's support for 8.1 version.
You have embedded missing data. Because of the recursive nature of the likelihood, you can't have that. You need to squeeze out the missing data points. See the description of the SAMPLE instruction.
Hello Tom:
Appreciate you very much for your help. I understood what you told me. However, I am using daily data in Canadian market so that there is no data at weekends or Canadian holidays. I have looked up Sample instruction, but I still have no idea how to squeeze out my missing data. What should I do with my daily data to make our daily consecutive?
cal(d) 2006:03:24
open data "D:\Documents and Settings\f_huan\My Documents\mutual fund thesisone_sample.xls"
sample (smpl=%valid(apexcess)) apexcess / apexcess_nomissing
linreg(define=fulleqn) apexcess
# constant aprm aprmsq
Just like what I wrote above, I used Sample instruction to create "compressed" version of data without any missing value to make my data consecutive entries. However, the mistakes appeared as follows. ## SX22. Expected Type SERIES[REAL], Got REAL Instead
>>>>=%valid(apexcess)) <<<<
I have solved the problem about missing value. Thanks for your help. However, when I put the code together and run them step by step. The mistakes appeared in the middle about EM 50 iteration, but when I continue to run the code in the following, the results could be shown as follows. Could you help me explain about that? Appreciate very much for your kindly help. A millions thanks.
cal(d) 2006:03:24
sample(smpl=%valid(apexcess)) apexcess / apexcess_nomissing
sample(smpl=%valid(aprm)) aprm / aprm_nomissing
sample(smpl=%valid(aprmsq)) aprmsq / aprmsq_nomissing
do emits=1,25
end do emits ## SR10. Missing Values And/Or SMPL Options Leave No Usable Data Points
@MSFilterInit
MAXIMIZE - Estimation by BHHH
NO CONVERGENCE IN 10 ITERATIONS
LAST CRITERION WAS 0.1477305
Daily(5) Data From 2006:03:24 To 2012:03:05
Usable Observations 1493
Skipped/Missing (from 1552) 59
Function Value 2987.6828
cal(d) 2006:03:24
sample(smpl=%valid(aprmsq)) aprmsq / aprmsq_nomissing calendar(irregular)
compute gstart=1,gend=%nobs
@msregression(states=2,switch=ch) apexcess_nomissing
# constant aprm_nomissing aprmsq_nomissing
When you do the SAMPLE, your data is no longer daily, but irregular with fewer observations. Add the two lines in red and deleting the existing line for setting gstart and gend should fix that.
Note, BTW, that the failure to converge on the last MAXIMIZE is intentional. That's just there to get the BHHH covariance matrix, which EM can't estimate itself.
Dear Tom:
Appreciate you very much for your help. I have put two lines in red as you suggested in my model. However, there were still mistakes as follows.The Error Occurred At Location 58, Line 7 of MSREGINITIAL Could you please help me figure it out ? Look forward to hearing from you. Thanks again.
cal(d) 2006:03:24
do emits=1,50
end do emits
@MSFilterInit
method=bhhh,iters=10) logl gstart gend The Error Occurred At Location 170, Line 13 of %MSINIT
Called From Location 127, Line 13 of MSFILTERINIT
## NL6. NONLIN Parameter P(1,1) Has Not Been Initialized. Trying 0
## NL6. NONLIN Parameter P(1,2) Has Not Been Initialized. Trying 0
The Error Occurred At Location 196, Line 19 of %MSPROB
I made one mistake about that previously. After I deleted the line for setting gstart and gend, everything is all right and perfect. The results are shown below. Thanks you very much for your kindly help and suggestions.
1. BETAS(1)(1) 0.000345991 0.000490941 0.70475 0.48096573
2. BETAS(1)(2) 0.604890635 0.026696461 22.65808 0.00000000
3. BETAS(1)(3) 0.187181525 0.686965627 0.27248 0.78525618
4. BETAS(2)(1) -0.006383747 0.006674866 -0.95639 0.33887737
5. BETAS(2)(2) 0.983682912 0.213718251 4.60271 0.00000417
6. BETAS(2)(3) 2.282115414 3.799917039 0.60057 0.54812656
7. SIGSQV(1) 0.000193687 0.000007508 25.79592 0.00000000
8. SIGSQV(2) 0.014987340 0.000506806 29.57217 0.00000000
9. P(1,1) 0.963136585 0.006720898 143.30475 0.00000000
10. P(1,2) 0.075835763 0.010634384 7.13119 0.00000000
Appreciate you very much for your help. Now I am begining with model with time varying probability by means of Filardo's logistic function as you suggested. However, my obersvation model is one multivariate linear regression without any lag so that I have to use code @msregression(states=2,switch=ch) apexcess_nomissing
nonlin(parmset=common) betas sigsqv[/color
Compared with Filardo's code using @MSVARSetup(lags=nlags)
nonlin(parmset=common) mu phi sigma, compute thisEntry(MSVARLagState(k,1),MSVARLagState(k,2))+=MSVARPTSM(time)(k) & @msvartestvector(domu,dovar) baseparms , these code is applied into markov swithcing VAR model. Therefore, I am not sure how to modify Filardo's code to fit into my multivariate linear regression with time varying probability. Could you please give me more suggestions about that?
Appreciate you very much for your constant instruction.
Now I am writing code for time-varying multivariate linear regression without no lag coefficients. The code is post as follows, but the mistake occurred in the bottom line. Just what I mentioned in the previous reply, I still didn't understand how to apply @msversteup (nonlin(parmset=common) mu phi sigma)
)into @msregression (nonlin(parmset=common) betas sigsqv)
I am trying my best to combine them, but the results can't be showns.I am not sure if I need the code such as @msvartestvector(domu,dovar) baseparms, do k=1,MSVARFilterSize
compute thisEntry(MSVARLagState(k,1),MSVARLagState(k,2))+=MSVARPTSM(time)(k), because in my tested model, there are no lag terms and state-dependent means. Moreover, without the codes above, is it possible to run one result?
Could you please give me more suggestions about that to modify the Filado's code?
Appreciate you very much for your help. Look forward to hearing from you .
cal(d) 2006:03:24
data(format=xls,org=cols) 2006:03:24 2012:03:05 apexcess aprm aprmsq logvix
sample(smpl=%valid(logvix)) logvix / logvix_nomissing
source msvarsetup.src
* Define the logistic index for the transitions
equation p1eq *
# constant logvix{1}
equation p2eq *
dec equation p1eq p2eq
dec vector v1 v2
nonlin(parmset=tv) v1 v2
function %MSVARPmat time
type rect %MSVARPmat
type int time
local integer i j
local rect pexpand
local real z
compute p(1,1)=%(z=exp(%dot(%eqnxvector(p1eq,time),v1)),z/(1+z))
compute p(1,2)=%(z=exp(%dot(%eqnxvector(p2eq,time),v2)),1/(1+z))
compute %MSVARInitTransition()
if nexpand==nstates {
dim pexpand(nstates,nstates-1)
ewise pexpand(i,j)=%if(i==nstates,-1.0,i==j)
compute %MSVARPmat=pexpand*p
ewise %MSVARPmat(i,j)=%if(i==nstates,1.0+%MSVARPmat(i,j),%MSVARPmat(i,j))
else {
dim %MSVARPmat(nexpand,nexpand)
ewise %MSVARPmat(i,j)=MSVARTransProbs(MSVARTransLookup(i,j))
Initialize the probabilities using only the intercepts
function TVPInit
type vector TVPInit
local rect a
local integer i j
compute p=||%logistic(v1(1),1.0),1-%logistic(v2(1),1.0)||
compute TVPInit=%MSVARInit()
procedure MSVARTVPEMEstimate start end
type integer start end
option integer iters 100
option real cvcrit 1.e-6
local integer emits time k
local series l11 l22 w11 w22
local vector baseparms testparms
local rect thisEntry
* @msvartestvector(domu,dovar) baseparmscompute baseparms=baseparms~~v1~~v2
do emits=1,iters
compute %eqnsetcoeffs(p1eq,v1)
compute %eqnsetcoeffs(p2eq,v2)
@msvarestep start end
compute %emlogl=%logl
@msvarmstep(nodop) start end
set l11 start end = 0.0
set l22 start end = 0.0
set w11 start end = 0.0
set w22 start end = 0.0
do time=start,end
compute %MSVARPMat(time)
compute thisEntry=%zeros(nstates,nstates) do k=1,MSVARFilterSize
end do k compute w11(time)=p(1,1)*(1-p(1,1))*(thisEntry(1,1)+thisEntry(2,1))
compute w22(time)=p(1,2)*(1-p(1,2))*(thisEntry(2,2)+thisEntry(1,2))
compute l11(time)=(thisEntry(1,1)- p(1,1)*(thisEntry(1,1)+thisEntry(2,1)))/w11(time)
compute l22(time)=(thisEntry(2,2)-(1-p(1,2))*(thisEntry(2,2)+thisEntry(1,2)))/w22(time)
end do time
* Update the coefficients
linreg(noprint,weight=w11,equation=p1eq) l11 start end
compute v1=v1+%beta
linreg(noprint,weight=w22,equation=p2eq) l22 start end
compute v2=v2+%beta
* Check for convergence
* @msvartestvector(domu,dovar) testparms compute testparms=testparms~~v1~~v2
compute %cvcrit=%testdiff(baseparms,testparms)
if %cvcrit<cvcrit
break
compute baseparms=testparms
disp "Iteration" emits "Log Likelihood" %emlogl %cvcrit
end do emits
end MSVARTVPEMEstimate
@MSVARTVPEMEstimate(cvcrit=.0001) gstart gend
maximize(parmset=tv+common,start=(pstar=TVPInit()),$
method=bhhh,iters=20) logltvtp gstart gend ## MAT15. Subscripts Too Large or Non-Positive The Error Occurred At Location 213, Line 16 of MSVARTESTVECTOR
Called From Location 59, Line 10 of MSVARTVPEMESTIMA
I am not sure if you have seen my posts. For these days, I have been trying my best to solve the problems concerning markov switching linear model with time vary transition probability. Under your help, I have firstly addressed the issue about fixed transition probability. However, to meet the requirement of thesis at Master level, I have to move further into time varying transition.
Just as what I post in the previous post, I combined @msregression with @msvarsetup and run every procedure step by step. There seems to be all right except for the last part with maximize likelihood (common+tv) followed by ## MAT15. Subscripts Too Large or Non-Positive
I am not sure if the error is related to irregular dataset, or should I set initial value for betas including constant (intercepts) and coefficients (betas and gammas) in the linear regression because I deleted the code line to initial value of mu in Filardo's code which is not considered in my model.
Could you please give me some advice about that? I wish that the problem can be solved under your further help.
cal(d) 2006:03:24
open data "one_sample_ap.xls"
calendar(irregular)
@msreginitial gstart gend
@MSFilterSetup(em)
dec vector v1 v2
dec vector p1mean p2mean
equation p1eq *
# constant
equation p2eq *
# constant
dim p1mean(1) p2mean(1)
compute p1mean(1)=1.0,p2mean(1)=1.0
* Function to compute the transition probability matrix
function %MSPmat time
type rect %MSPmat
type int time
local integer i j
local rect pexpand
local real z
local rect p
dim p(1,2)
compute %MSInitTransition()
compute %MSPmat=pexpand*p
ewise %MSPmat(i,j)=%if(i==nstates,1.0+%MSPmat(i,j),%MSPmat(i,j))
else {
dim %MSPmat(nexpand,nexpand)
ewise %MSPmat(i,j)=MSTransProbs(MSTransLookup(i,j))
* Initialize the probabilities using only the means
function TVPInit
type vector TVPInit
local rect a
local integer i j
dim p(1,2)
compute p(1,1)=%(z=exp(%dot(p1mean,v1)),z/(1+z))
compute p(1,2)=%(z=exp(%dot(p2mean,v2)),1/(1+z))
compute TVPInit=%MSInit()
compute p=%MSPExpand(p)
procedure MSTVPEMEstimate start end
dim thisEntry(nstates,nstates)
compute baseparms=v1~~v2
do emits=1,iters
compute TVPInit()
@MSRegestep start end
@MSRegmstep(nodop,nodobeta,dosigma) start end
compute tvemlogl=0.0
do time=start,end
compute p=%MSPMat(time)
do k=1,MSEMSize
compute thisEntry(MSEMLagRegime(k,1),MSEMLagRegime(k,2))+=MSEMpt_sm(time)(k)
compute tvemlogl+=log(p(MSEMLagRegime(k,1),MSEMLagRegime(k,2)))*MSEMpt_sm(time)(k)
end do k
end do time
compute v1=v1+%beta
compute v2=v2+%beta
do time=start,end
do k=1,MSEMSize
end do k
end do time
compute testparms=v1~~v2
if %cvcrit<cvcrit
break
end do emits
end MSTVPEMEstimate
compute v1=log(.7/.3)
compute v2=log(.95/.05)
@MSTVPEMEstimate(cvcrit=.0001) gstart gend
equation p1eq *
equation p2eq *
dim p1mean(%eqnsize(p1eq)) p2mean(%eqnsize(p2eq))
do i=1,%eqnsize(p1eq)
sstats(mean) gstart gend %eqnxvector(p1eq,t)(i)>>p1mean(i)
do i=1,%eqnsize(p2eq)
sstats(mean) gstart gend %eqnxvector(p2eq,t)(i)>>p2mean(i)
compute v1=v1~~0.0
compute v2=v2~~0.0
@MSTVPEMEstimate(cvcrit=.0001,iters=50) gstart gend
* Polish estimates using BHHH
frml logltvtp = p=%MSPMat(t),log(%MSRegProb(t))
@MSFilterInit
maximize(parmset=tv+common,start=(pstar=TVPInit()),method=bhhh,iters=10) logltvtp gstart gend
