Uhlig JME 2005 Sign-Restricted IRF's for VAR
Re: Uhlig JME 2005 Sign-Restricted IRF's for VAR
Aren't they going to look the same other than scale? 72 virtually identical graphs will look rather uninteresting no matter how you arrange them. You can't combine them on a single graph or they'll just smear together. Maybe just graph a few representatives.
RK2509
Unread post by RK2509 »
Is this correct?
dec rect[series] Z(N,1)
do i=1,N
set Z(i,1) = lambda(i,1)*goodresp(t)(k,3)
Thanks a ton for all your help.
Kind Regards
RK2509
I know they'll pretty much look the same. But that would always be the case when we try to analyse the shock on 72 food prices through the latent factor lambda. I would perhaps go with a few graphs as you advised.
umee
Unread post by umee »
Would it be incorrect to try to interpret Uhilg's shock in terms of the federal funds rate? In other words, how does shock generated by sign restriction compare to a 50 basis point fed funds shock?
I guess you could do that. However, note that the "size" of a shock in the Uhlig procedure is determined by it being an impulse vector (column out of a factorization of the covariance matrix) and not any specific impact on any variable.
umee
One follow up, which is not necessarily related to code. What would be the implication of Uhlig remaining agnostic about the price level (GDP deflator) as well?
If you're talking about multiple shocks, have you looked at Mountford and Uhlig?
umee
Not multiple shocks, less restrictions. Being agnostic about output and the price level.
Fewer restrictions? Then you might end up with a smear of very different shocks. There's a fine line between having enough restrictions to actually "identify" the desired behavior and so many that no shocks actually satisfy them.
umee
In regards to code you posted for Uhlig 2005, is the behavior of the federal funds rate in the impulse vector consistent with a 50 basis point federal funds rate shock under recursive estimation?
In other words, if I want to compare the results generated by this code to results from the recursive approach. Can I make straight forward comparisons? Would the one standard deviation shock to the impulse vector coincide with a 50 basis point increase in the federal funds rate?
Didn't you already ask that?
umee
Sort of, but is it not possible to make sure that the federal fund rate change is consistent across both methods?
It's a sign restriction, not a size restriction. Although you can generate a sign-restricted impulse vector and then scale it to have a specific impact, that completely alters the probability. For instance, if you have an accepted impulse vector with a .05 impact on the FFR and you scale it up to .50, you're now taking a 10 standard deviation shock which should have probability effectively zero.
tasnim223
Unread post by tasnim223 »
I have bit of confusion in Uhligh1.rpf.
First , if I want to give shock to the real GDP , that is the first variable, do I make the following changes,
if atest(1)<0
compute a=-1.0*a
also if I want to want to give it a negative shock , do I change the following things;
if atest(1)<0
compute a=1.0*a
Many thanks
Rosen
I'm not sure what you mean by "give a shock to real GDP". That's not how sign restrictions work.
