Hasbrouck(1995) Information Shares
sheriared
Re: Hasbrouck(1995) Information Shares
Unread post by sheriared »
A full example is provided by hasbrouck.rpf. This does the calculation with both an empirically chosen cointegrating vector and also the theoretical cointegrating space (which has a single common trend).
In the example with empirically determined cointegrating vector, is it possible to change to a 3-variable system with 2 cointegrating vectors?
Many thanks!
Frank
Unread post by Frank »
TomDoan wrote:Isn't that the same thing but with:
* Compute Cholesky factorization of sigma
compute f=%decomp(%sigma)
replaced with an eigenvalue-based factorization
eigen(dmatrix=identity) %sigma * f
Sorry, didn't get it. Did you mean:
compute f=eigen(dmatrix=identity) %sigma
* Compute decomposition of long-run variance
compute split=psi*f
dis "split=" split
compute contrib=split.^2
Frank
No, I meant
EIGEN is an instruction, not a function (it has quite a few options to allow it to deal with real or complex matrices).
Frank
TomDoan wrote:No, I meant
Tom,
I know eigen is an instruction, but if
compute f=%decomp(%sigma) is replaced by eigen(dmatrix=identity) %sigma * f
how about the matrix "f" ?
I used the new code to calculate but the result is nothing different to the results of Cholesky factorization of sigma.
I have no idea what's going on.
If you do it correctly, that's only possible if %sigma is diagonal
compute split=psi*f
compute [vector] variance=contrib*%fill(%cols(contrib),1,1.0)
ewise contrib(i,j)=contrib(i,j)/variance(i)
disp "Decomposition of Long-run variance" contrib
compute split=psi*f
with Cholesky
0.68224 0.31776
0.68224 0.31776
with eigen
0.84417 0.15583
0.84417 0.15583
Last bumped by TomDoan on Tue Aug 15, 2023 3:37 pm.
