trivariate DCC with VAR(1) MEAN EQUATIONS
xyzh
Re: trivariate DCC with VAR(1) MEAN EQUATIONS
Unread post by xyzh »
Here's an example paper:
http://ideas.repec.org/a/eee/quaeco/v47 ... l#download
Hope u will understand what i said.
Zhang
xyzh
moderator wrote:Including asymmetry terms is covered in the manuals. See "GARCH" in the Reference Manual and Chapter 12 in the User's Guide.
the manual demonsrates the GJR ,right?
My question is about estimating a ADCC model, am I right?
Tks.
Zhang
xyzh
I have a new problem now with the MVGARCH-DCC. After adding "variance=varma" option i got the results like this:
  • Variable Coeff Std Error T-Stat Signif
    1. Mean(1) 0.000145192 0.000298354 0.48664 0.62651077
    2. Mean(2) 0.000452759 0.000251361 1.80123 0.07166673
    3. Mean(3) 0.000307494 0.000043419 7.08208 0.00000000
    4. C(1) -0.000000217 0.000000529 -0.41026 0.68161615
    5. C(2) 0.000000710 0.000000564 1.25993 0.20769582
    6. C(3) 0.000000155 0.000000045 3.42794 0.00060818
    7. A(1,1) 0.057933592 0.016794974 3.44946 0.00056171
    8. A(1,2) -0.065924827 0.025252117 -2.61067 0.00903663
    9. A(1,3) 0.048611966 0.132020640 0.36821 0.71271301
    10. A(2,1) -0.031016545 0.016435385 -1.88718 0.05913600
    11. A(2,2) 0.102465005 0.025064940 4.08798 0.00004351
    12. A(2,3) -0.096694866 0.135042222 -0.71603 0.47397015
    13. A(3,1) 0.005105719 0.005538758 0.92182 0.35662423
    14. A(3,2) 0.009217814 0.006968065 1.32287 0.18588005
    15. A(3,3) 0.098969648 0.028962153 3.41721 0.00063267
    16. B(1,1) 0.904499342 0.023065961 39.21360 0.00000000
    17. B(1,2) 0.196648202 0.052423936 3.75111 0.00017605
    18. B(1,3) -2.498101504 0.993974355 -2.51325 0.01196261
    19. B(2,1) 0.063046957 0.030820503 2.04562 0.04079403
    20. B(2,2) 0.872904440 0.031369087 27.82690 0.00000000
    21. B(2,3) -0.260539758 0.444913701 -0.58560 0.55814692
    22. B(3,1) -0.091754291 0.037002318 -2.47969 0.01314965
    23. B(3,2) 0.020923602 0.030008992 0.69724 0.48564984
    24. B(3,3) 0.851193338 0.033443870 25.45140 0.00000000
    25. DCC(1) 0.009226038 0.003358069 2.74742 0.00600656
    26. DCC(2) 0.988152157 0.006115655 161.57750 0.00000000
    27. Shape 8.273972673 1.325200506 6.24356 0.00000000
Im confused what the non-diagonal elements mean?
That's explained in the manual. VARIANCES=VARMA is an extension of the CC/DCC type model allowing each variance to depend upon the other variances and the other lagged squared residuals. Those terms give those off-diagonal coefficients.
gembala119
Unread post by gembala119 »
Dear Sir
After we do trivariate or bivariate garch model, how we make graphs of variance and covariance of bivariate or trivariate
thank you very much
kim
xyzh
gembala119 wrote:Dear Sir
kim
you can graph the variance and covariance with RATs by using the command "graph" plus some options or you can print the results and graph it with Excel.
thank you very much
kim
This is from GARCHMV.PRG which graphs the correlations from a multivariate GARCH, with grid lines at the CC estimates.
* GARCHMV.PRG
* Manual Example 12.2
open data g10xrate.xls
data(format=xls,org=columns) 1 6237 usxjpn usxfra usxsui
garch(p=1,q=1,iters=200,hmatrices=hh) / xjpn xfra xsui
garch(p=1,q=1,mv=bek,method=bfgs,iters=200,pmethod=simplex,piters=10) / xjpn xfra xsui
garch(p=1,q=1,mv=diag,hmatrices=hd,rvectors=rd) / xjpn xfra xsui
garch(p=1,q=1,mv=cc) / xjpn xfra xsui
garch(p=1,q=1,mv=dcc,method=bfgs) / xjpn xfra xsui
* Compute the covariance matrix of the standardized residuals from
* the diagonal GARCH
set z1 = rd(t)(1)/sqrt(hd(t)(1,1))
set z2 = rd(t)(2)/sqrt(hd(t)(2,2))
set z3 = rd(t)(3)/sqrt(hd(t)(3,3))
vcv(matrix=cc)
# z1 z2 z3
* Compute the correlations from the multivariate GARCH
set rho12 = hh(t)(1,2)/sqrt(hh(t)(1,1)*hh(t)(2,2))
set rho13 = hh(t)(1,3)/sqrt(hh(t)(1,1)*hh(t)(3,3))
set rho23 = hh(t)(2,3)/sqrt(hh(t)(2,2)*hh(t)(3,3))
graph(header="Correlation of JPN with FRA",vgrid=||cc(1,2)||)
# rho12
graph(header="Correlation of JPN with SUI",vgrid=||cc(1,3)||)
# rho13
graph(header="Correlation of FRA with SUI",vgrid=||cc(2,3)||)
# rho23
You also might want to look at tsayp452.prg from the Tsay textbook examples.
