Sign restriction - Historical Decomposition
Re: Sign restriction - Historical Decomposition
if UhligAccept(a,KMIN,KMAX+1,||+5,-1,-3,-4||)==0
If I'm reading your model correctly, you have a restriction with one interest rate going up (+5) and one down (-3) for five consecutive periods. That sounds like it would be hard to achieve.
cordura
Unread post by cordura »
I am working on an empirical study using sign restriction, identifying multiple shocks. I am wondering if there are any possibilities that RATS can realize the plotting of structural innovation of each shocks?
cheers
cordura wrote:Dear Tom,
cheers
Sure. That's much simpler than the historical decomposition. For an accepted draw using weights A, you just take a series formed by TR(A)*INV(SWISH)*XT(U,T). Whether that will be particularly interesting is another matter---I'm guessing that the bands across draws will be quite wide.
luching
Unread post by luching »
Hi Tom, I have a VAR with 2 variables only. In this system, is it possible to impose two sets of sign restrictions to identify two different structural shocks simultaneously and also impose that the two shocks are orthogonal? Doesn't this result in some sort of singularity problem?
luching wrote:Hi Tom, I have a VAR with 2 variables only. In this system, is it possible to impose two sets of sign restrictions to identify two different structural shocks simultaneously and also impose that the two shocks are orthogonal? Doesn't this result in some sort of singularity problem?
Almost. Once you've picked one shock, the other is forced by the orthogonality constraint. However, you can still reject the pair of shocks if they don't meet a set of desired restrictions.
