Can I solve a nonlinear equation by Rats?
Re: Can I solve a nonlinear equation by Rats?
It's not able to come up with a bond value which solves the problem starting with .16. I would look at your calculation of the numerical integral---it's possible that that's not sufficiently accurate as you have it set up.
T_FIELD
Unread post by T_FIELD »
Thank you so much for your kind suggestion.
I will see the integral.
As soon as I get something meaningful, we will get back to you.
