Page 4 of 6
Re: Gray JFE 1996 Markov Switching GARCH model
Posted: Fri Jun 16, 2017 9:28 am
by jack
Thank you for your kind reply.
Here is the code which is an adjusted version of your code:
* All of this was out of Gray's paper, "Modeling the conditional
* distribution of interest rates as a regime-switching process", J. of
* Financial Economics 42, 1996, pp 27-62.
* Revision Schedule:
*   01/2005 Written by Tom Doan, Estima
*   09/2005 Comments added. Changed to use new %MSSMOOTH procedure
*   08/2011 Changed to use the new MSSETUP procedures.
OPEN DATA "D:sf.xlsx"
CALENDAR(D) 2002:1:3
DATA(FORMAT=XLSX,ORG=COLUMNS) 2002:01:03 *** data rate
set rate = rate*100.0
spgraph(vfields=2,window="Figure 3")
graph(header=" Exchnage Rate")
# data
graph(header="Daily  Exchange Rate Return")
# rate
* This makes extensive use of the Markov switching functions and
* procedures from MSSetup.src
@MSSetup(states=2)
* The P and Q values in Gray's notation are handled in MSSetup as an M-1
* x M matrix (called P here), with P(i,j) giving the probabilities of
* moving from state j to state i. The Mth row is implicit, as it's just
* the 1-sum of rest of the column.
* Table 1 information
stats rate
cmom(corr,print)
# rate rate{1}
* Table 2 estimates
* Single regime is linear regression
linreg(robust) rate
# constant rate{1}
* We're going to use these later for initial conditions
compute olsvar =%seesq
compute olsbeta=%beta
* Constant variance regime switching model
* This uses Gray's notation for all the variables other than "P"
nonlin a01 a02 a11 a12 b01 b02 p
* Initial guess values for MS models are always a bit tricky because the
* model isn't globally identified. This is starting with OLS results for
* state 1 and 0 mean coefficients for state 2.
compute a01=olsbeta(1),a11=olsbeta(2),b01=sqrt(olsvar)
compute a02=a12=0.0,b02=b01
* The p matrix is initialized to make both states fairly persistent.
* (The 2,2 transition is 1-.1=.9).
compute p=||.8,.1||
* SimpleRegimeF returns the 2-vector of densities in the two regimes. It
* is specific to the data series used (dependent variable <<rate>>) and
* the precise parameterization, and so would need to be altered slightly
* for a different application. Note that this needs to return the actual
* density, not its log.
function SimpleRegimeF t
type vector SimpleRegimeF
type integer t
compute SimpleRegimeF=||%density((rate(t)-a01-a11*rate(t-1))/b01)/b01,$
                        %density((rate(t)-a02-a12*rate(t-1))/b02)/b02||
* This is the standard log likelihood FRML for a Markov switching model.
frml logl = f=SimpleRegimeF(t),fpt=%MSProb(t,f),log(fpt)
@MSFilterInit
maximize(start=(pstar=%MSInit()),method=bfgs,iters=100,pmethod=simplex,piters=5) logl 2 ***
* It's not clear what residuals are used for the diagonostics for the
* regime switching model. The standardized residuals weighted by the ex
* ante probabilities of the two states seem to give LB's which are
* fairly close to those in the paper.
set ustd = %dot(pt_t1,||(rate-a01-a11*rate{1})/b01,(rate-a02-a12*rate{1})/b02||)
graph
# ustd
set usqr = ustd^2
@regcorrs(report,number=15) usqr
* Compute the smoothed probabilities and the ex ante probabilities
@MSSmoothed %regstart() %regend() psmooth
set exante %regstart() %regend() = pt_t1(t)(1)
set smooth %regstart() %regend() = psmooth(t)(1)
* And the conditional standard deviation
set condstddev = sqrt(exante*b01^2+(1-exante)*b02^2)
spgraph(vfields=2,window="Figure 4")
graph(max=1.0,header="Regime Probabilities") 2
# exante
# smooth
graph(header="Conditional Standard Deviation")
# condstddev
* Table 3 estimates
* Single regime GARCH model
garch(p=1,q=1,reg,resids=u,hseries=h) / rate
# constant rate{1}
compute onestate=%beta
set usqr = u^2/h
@regcorrs(number=15,report) usqr
set usqr1 = u/h
@regcorrs(number=15,report) usqr1
* Regime-switching GARCH
nonlin a01 a02 a11 a12 b01 b11 b21 b02 b12 b22 p
compute a01=%beta(1),a11=%beta(2),b01=olsvar,b11=0.0,b21=0.0
compute a02=%beta(1),a12=%beta(2),b02=%beta(3),b12=%beta(4),b22=%beta(5)
compute p=||.95,.05||
set uu = olsvar
set h  = olsvar
* RegimeGARCHF returns the 2 vector of densities in the two regimes.
* Again, many lines in this are specific to the problem at hand.
function RegimeGARCHF t
type vector RegimeGARCHF
type integer t
local real hh1 hh2 mu1 mu2 mu
* Compute state dependent variances
compute hh1=b01+b11*uu(t-1)+b21*h(t-1)
compute hh2=b02+b12*uu(t-1)+b22*h(t-1)
* Compute state dependent means
compute mu1=a01+a11*rate(t-1)
compute mu2=a02+a12*rate(t-1)
* Compute the return vector (densities in the two states)
compute RegimeGARCHF=||%density((rate(t)-mu1)/sqrt(hh1))/sqrt(hh1),$
                       %density((rate(t)-mu2)/sqrt(hh2))/sqrt(hh2)||
* Compute the values of uu (squared residual) and h (variance) to be
* used for the period following.
compute mu=mu1*pstar(1)+mu2*pstar(2)
compute uu(t)=(rate(t)-mu)^2
compute h(t)=pstar(1)*(mu1^2+hh1)+pstar(2)*(mu2^2+hh2)-mu^2
frml logl = f=RegimeGARCHF(t),fpt=%MSProb(t,f),log(fpt)
* This combination is able to locate Gray's results - the first MAXIMIZE
* works with the "p" matrix fixed at a fairly high level of persistence,
* and tries to get estimates which separate the two states. The second
* then adds the p matrix to the parmset.
maximize(start=(pstar=%MSInit()),method=bfgs,iters=100,pmethod=simplex,piters=50) logl 2 ***
maximize(start=(pstar=%MSInit()),method=bfgs,iters=100) logl 2 ***
set usqr2 2 * = uu(t)/h(t)
@regcorrs(title="Squared Standardized Residuals from MS GARCH",$
number=15,report) usqr2
graph
# usqr2
@regcorrs(report,number=15) usqr2
@westchotest(number=5) usqr2
@westchotest(number=10) usqr2
@westchotest(number=15) usqr2
set usqr3 = usqr2^.5
@regcorrs(title="Standardized Residuals from MS GARCH",$
number=15,report) usqr3
graph
# usqr3
set condstddev = sqrt(h)
spgraph(vfields=2,window="Figure 5")
# exante
# smooth
# condstddev
* However, this set of initial guess values (which are actually the
* result of a typo in trying to reproduce the article's numbers) find a
* local max with quite a bit higher likelihood, and dramatically
* different behavior. How one might find this systematically is unclear.
compute a01=.1407,a02=-.0011,a11=-.0141,a12=.0006,b01=.0004,b11=.4609,b21=.1977,b02=.0099,b12=.1655,b22=.2685,p=||.9739,1-.9896||
And data:
sf.xlsx
data
(84.64 KiB) Downloaded 2251 times
Posted: Fri Jun 16, 2017 10:57 am
My suggestion would be to update to version 9.2. The two new optimization methods (simulated annealing and genetic annealing) were added precisely to handle these ill-behaved Markov Switching models.
Posted: Wed Jun 21, 2017 12:43 pm
by jack
I updated RATS to version 9.2. So how I can use these new optimization methods (simulated annealing and genetic annealing) for handling this ill-behaved Markov Switching model? You mean I use these methods instead of bfgs or pmethod=simplex? Which one you recommend exactly simulated annealing or genetic annealing?
Posted: Wed Jun 21, 2017 1:00 pm
PMETHOD=GA,PITERS=5 seems to work fairly well (takes a while, though). You still want to use BFGS to do the final estimates.
Posted: Wed Jun 21, 2017 2:01 pm
by jack
I run the model but I got this error:
The Error Occurred At Location 480, Line 47 of REGCORRS
C:\Users\Public\Documents\Estima\WinRATS Std 9.2\regcorrs.src Line 84
And here is a part of the results for MS-GARC model:
MAXIMIZE - Estimation by BFGS
Convergence in 92 Iterations. Final criterion was 0.0000000 <= 0.0000100
Daily(5) Data From 2002:01:04 To 2013:01:02
Usable Observations                      2869
Function Value                        NA
1.  A01                          -0.075397835  0.025443933     -2.96329  0.00304366
2.  A02                           0.101946815  0.031964676      3.18936  0.00142589
3.  A11                          -0.043306625  0.029069235     -1.48978  0.13628337
4.  A12                           0.175908723  0.040523341      4.34092  0.00001419
5.  B01                           0.062676131  0.015956197      3.92801  0.00008565
6.  B11                           0.041545516  0.014834514      2.80060  0.00510079
7.  B21                           0.637607820  0.013189178     48.34326  0.00000000
8.  B02                          -0.062054395  0.042949832     -1.44481  0.14851095
9.  B12                           0.031547997  0.015037874      2.09790  0.03591374
10. B22                           1.739034640  0.053443699     32.53956  0.00000000
11. P(1,1)                        0.629306839  0.025874162     24.32182  0.00000000
12. P(1,2)                        1.000010000  0.014288789     69.98564  0.00000000
Posted: Thu Jun 22, 2017 7:03 am
by jack
I tried several times but unfortunately I got the same error or something like it.
I do not know what's wrong with the model.
Posted: Thu Jun 22, 2017 10:28 am
Probably that's it's unnecessarily complicated. Your series seems to be fit perfectly reasonably by a single regime GARCH model.
Posted: Thu Jun 22, 2017 12:14 pm
by jack
So what can one say about this single regime GARCH model? Is it the high volatility regime or low volatility regime?
Posted: Thu Jun 22, 2017 12:30 pm
It's one regime. A GARCH model has different levels of volatility based upon the data (that's the whole point). MS-GARCH models don't work in practice because the memory of the GARCH model and the memory of the MS process are competing to explain basically the same thing.
Posted: Thu Jun 22, 2017 3:51 pm
by jack
I am really really sorry for asking these questions and taking your time.
I would be grateful if you could possibly guide me how I can adjust the gray' code for obtaining the model has has been used in this paper:
http://onlinelibrary.wiley.com/journal/ ... ntact.html
I know that it is a combination of Gray's paper and Dueker's paper but I cannot reproduce their model.
Posted: Thu Jun 22, 2017 6:58 pm
by jack
I'm sorry. Here is the link to the paper:
http://onlinelibrary.wiley.com/doi/10.1 ... 3/abstract
Posted: Thu Jun 22, 2017 7:38 pm
They have a footnote that says they did that with RATS. Have you tried contacting the authors?
Posted: Thu Jun 22, 2017 11:41 pm
by jack
I tried several times but they didn't replied to any of my Emails.
I'm disappointed from their reply.
Posted: Fri Jun 23, 2017 12:53 pm
by jack
I'm really sorry for asking this question. I know that your are very busy.
Is it possible to have a code for this paper here? Or is it possible to guide me for writing a code for it?
I read those code for Gray and Dueker but I cannot combine the for writing a new code.
Posted: Fri Jun 23, 2017 2:03 pm
I addressed my impressions of the paper when you first brought that up:
https://estima.com/forum/viewtopic.php?p=13722#p13722
so the answer is no. My very strong suggestion is that you look through the literature review in that paper to see what other people have done with the dummy variable approach and use that.
Note, also, that the only thing that takes out of Dueker is the t-distributed errors. Other than that, they're using the Gray filter.
