Page 5 of 6
Re: VAR-GARCH-M
Posted: Mon Jun 04, 2012 3:59 pm
by economics2012
Ooops I am sorry.
So , If I understood you correctly, I need to set zero the daily variances that are negative (i.e. GARCHP(1)(2), GARCHP(1)(4), GARCHP(1)(5), GARCHP(2)(2), GARCHP(2)(4)) correct? And the ones with positive signs, if they are significant it means we have daily effect. Am i right?
This is the code ans the sries is attached.
Again, I truly appreciate all your help.
Re: VAR-GARCH-M
Posted: Thu Jun 07, 2012 11:09 pm
by economics2012
I need to run the IRFs after estimating the GARCH model taking into account the day of the week effect.
How can I adjust this line in the code below?
compute hirf(i+1)=garchp(1)(3)*hirf(i)+garchp(1)(2)*%if(i==1,eps0(1)^2,hirf(i)
Many Thanks
Re: VAR-GARCH-M
Posted: Fri Jun 08, 2012 9:48 am
The deterministics don't affect the IRF's, so you just need to make sure you get the right slots for the two "GARCH" lag coefficients.
Re: VAR-GARCH-M
Posted: Fri Jun 08, 2012 2:25 pm
by economics2012
I am running this code for the IRFs
And getting this error
Re: VAR-GARCH-M
Posted: Fri Jun 08, 2012 3:30 pm
If you do
Show Last Error on the
Edit Menu, it will take you to the instruction which causes the problem, which is:
[u] compute hirf(i+1)=garchp(1)(7)*hirf(i)+garchp(1)(6)*%if(i==1,eps0(1)^2,hirf(i))[/u]
You have forum post underscore tags on the instruction.
Re: VAR-GARCH-M
Posted: Fri Jun 08, 2012 4:00 pm
by economics2012
Thanks a lot Tom, but I don't see what is wrong with :
garchp(1)(7) and garchp(1)(6) stand for the GARCH lags!
Re: VAR-GARCH-M
Posted: Fri Jun 08, 2012 9:05 pm
by moderator
There's nothing wrong with it. Your program had at the start of the instruction and at the end. Those will give syntax errors.
Re: VAR-GARCH-M
Posted: Mon Jun 11, 2012 4:05 pm
by economics2012
Using quarterly or monthly data, we usually include a full year of lags given that the primary effect of oil prices occurs at one year (based on the arguments by Hamilton and Herrera (2004)). Now, for daily data, since I have a large sample size (over 6000), the AIC/BIC criterion will do for selecting the sufficient number of lags in the mean equation. Can you please help me testing it in RATS? I have read Chapter 4 of Leamer's Specification Searches (Wiley, 1978) but still not sure how related to this.
Many thanks.
Re: VAR-GARCH-M
Posted: Tue Jun 12, 2012 8:05 am
by moderator
Just apply the standard @VARLagSelect to the model without any of the "M" terms. You're just trying to pick a defensible number of lags. If you tried to pick the number of lags based upon the full model, it would probably take a couple of days to estimate all the required models, and you would probably end up with the same answer.
Re: VAR-GARCH-M
Posted: Fri Jun 22, 2012 12:08 am
by economics2012
I am running the IRFs for the GARCH(2,1) model with 7lags and I just want to make sure the line below is correct:
compute hirf(i+1)=garchp(1)(4)*hirf(i)+garchp(1)(3)*hirf(i)+garchp(1)(2)*%if(i==1,eps0(1)^2,hirf(i))
This is the code:
Thanks a lot
Re: VAR-GARCH-M
Posted: Fri Jun 22, 2012 7:24 am
No. It's not allowing for the second lag on the H. The recursion changes to:
compute hirf(i+1)=garchp(1)(4)*hirf(i)+garchp(1)(3)*hirf(i)+garchp(1)(4)*%if(i==1,0.0,hirf(i-1))+garchp(1)(2)*%if(i==1,eps0(1)^2,hirf(i))
Re: VAR-GARCH-M
Posted: Tue Jun 26, 2012 8:17 am
Take out the colored part of this.
Re: VAR-GARCH-M
Posted: Mon Apr 22, 2013 4:03 pm
by economics2012
I am trying to check for the effect of uncertainty in oil price on stock returns for periods t and (t-1), and I need to get psi1 and psi2 of equation one in the attached below model.
Can you please help me adjust the model accordingly?
Your help is highly appreciated in this regard.
Re: VAR-GARCH-M
Posted: Mon Apr 22, 2013 4:41 pm
Isn't the only change to add the lag of sqrthoil to the model?
Re: VAR-GARCH-M
Posted: Mon Apr 22, 2013 9:47 pm
by economics2012
Correct, but I am not sure how to add the lag of sqrthoil to the model.
Can you please help me?
Thanks a lot
