Balke(2000) Threshold VAR
Re: Balke(2000) Threshold VAR
Yes. Use the correct value for SSTART. Your working sample starts one period later.
pbrigante
Can you say me where I´m wronging in these irf´s ? Why are they have such irregulars moviments ?
Greatful !
Greatful !
- respchoquemon_tight_semvar_gpib.RGF
- (3.67 KiB) Downloaded 1148 times
Isn't your output measure in growth rates? That's what responses of growth rates look like.
pbrigante
please ! I have some doubts about how to interpreat the results of the Nlirf´s.
1. How Can I know if the variables to react significantly on shocks ?
2. In the file in attachment, for example, is it correct to conclude that the responses of the variables: "produto" (product) and "inflação" (inflation) not react significantly on monetary shock ?
Greatful
Greatful
- Response_high_-.RGF
- (2.63 KiB) Downloaded 1181 times
There's no simple way to do that. The NLIRF's require a double level bootstrap just to get the point estimates. Confidence bands would require a completely new level of simulations to vary the model coefficients as well.pbrigante wrote:Hi Tom,
No. For instance, the values on the Produto IRF depend upon the relative scales of the two variables.pbrigante wrote: 2. In the file in attachment, for example, is it correct to conclude that the responses of the variables: "produto" (product) and "inflação" (inflation) not react significantly on monetary shock ?
Jules89
again I have a follow up question on the near-T-VAR. You said that I have to use SUR on different subsamples and then add the %logls.
1) How would I define the subsamples. For SUR there does not exist the convenient GROUP function. How can I use the SMPL option on SUR to get estimation for all the different subsamples?
2) What do you precisely mean by adding the %logls for the subsamples? Do you mean that when I have a threshold and estimate a lower and upper SUR, that I have to add the two %logls resulting from the two models defined by the sample split?
Best
Jules
Best
Jules
SUR with SMPL=credthr{d}<=thresh and SUR with SMPL=credthr{d}>threshJules89 wrote:Dear Tom,
Correct. Note that that will only give you the estimation with heterogeneous covariance matrices---there is no simple way to get a common covariance matrix when you are using SUR. (With identical regressors, the coefficients in each subsample are independent of the choice of covariance matrix, which is not true with a near-VAR).Jules89 wrote: 2) What do you precisely mean by adding the %logls for the subsamples? Do you mean that when I have a threshold and estimate a lower and upper SUR, that I have to add the two %logls resulting from the two models defined by the sample split?
Jules89
that means that running the bootstrap tests as in Balke (2000) is going to be difficult. Do you thing the distortion from using var=hetero in the bootstrap is large?
Another question: why using sur rather thsn estimate?
Best
Jules
Best
Jules
That's hard to say, since the fixed regressor bootstrap won't apply otherwise.Jules89 wrote:Thanks,
ESTIMATE does least squares equation by equation (whether that's maximum likelihood or not). SUR does joint estimation (whether it's needed to not).Jules89 wrote: Another question: why using sur rather thsn estimate?
Last bumped by TomDoan on Sat Nov 09, 2024 11:36 am.
