UV garch model forecasts
ac_1
Re: UV garch model forecasts
Unread post by ac_1 »
Here's a concrete example using the g10xrate.xlsx file (which I have called g10xrate(dates).xlsx) from here viewtopic.php?p=19829#p19829
OPEN DATA "g10xrate(dates).xlsx"
DATA(FORMAT=XLSX,NOLABELS,ORG=COLUMNS,TOP=2,JULIAN=DATE) / USXJPN USXFRA USXSUI USXNLD USXUK USXBEL USXGER USXSWE USXCAN USXITA
CALENDAR(JULIAN=DATE)
*OPEN DATA "g10xrate(dates).xlsx"
*DATA(FORMAT=XLSX,NOLABELS,ORG=COLUMNS,TOP=2) / USXJPN USXFRA USXSUI USXNLD USXUK USXBEL USXGER USXSWE USXCAN USXITA
declare vector[real] hhat_1(%allocend()+1)
set p = usxjpn
set lp = log(p)
diff lp / dlp
set y = 100.0*dlp
comp WIN = 6200
compute tstart= 1
compute tend  = WIN
do jj = 0, %allocend()-WIN-1
   garch(p=1,q=1,resids=u,hseries=h,print,METHOD=BFGS) tstart+1+jj tend+1+jj y
   * Compute the one-step forecast for the variance
   comp hhat = ( %beta(2) + %beta(3)*u(tend+1+jj)^2 + %beta(4)*h(tend+1+jj) )
   comp hhat_1((tend+1+jj+1)) = hhat
   disp 'obs' WIN+1+1+jj 'GARCH 1-step ahead forecast'  hhat
end do jj
SET vhhat_1 WIN+1+1 %allocend()+1 = hhat_1(t)
prin / vhhat_1
graph 1
# vhhat_1
View -> Series Window
Not using the dates -- that's correct.
Name    Obs  F Dates
vhhat_1  37  U 6202 6238
Using the dates -- that's not correct.
Name    Obs  F Dates
vhhat_1  37  i 1973:01:02 1973:02:23
However, if I prin and graph the dates are correct 1997:09:17 1997:11:07.
Why is this happening?
The series are correct; the display in the Series window isn't. The Series window was designed for displaying information with standard dates (it was originally for displaying RATS data files) and wasn't adapted to mapped dates, which require a separate "time series" of information with the dates. We're working on it, but it's not a simple fix.
ac_1
TomDoan wrote: ↑Thu Nov 06, 2025 8:17 am The series are correct; the display in the Series window isn't. The Series window was designed for displaying information with standard dates (it was originally for displaying RATS data files) and wasn't adapted to mapped dates, which require a separate "time series" of information with the dates. We're working on it, but it's not a simple fix.
Understood - thanks Tom.
ac_1
OPEN DATA dat.txt
DATA(FORMAT=PRN,NOLABELS,ORG=COLUMNS) 1 100 DLP SVAR
comp SCALE = 100
set ftrigger %allocend()-99 %allocend() = sVaR/SCALE
set trigger %allocend()-99 %allocend() = dlp < -ftrigger
prin / dlp ftrigger trigger
sstats %allocend()-99 %allocend() trigger>>ntrigger
disp ntrigger
table %allocend()-99 %allocend() trigger
set xdots %allocend()-99 %allocend() = %if(trigger==1,dlp,%na)
prin / xdots
trigger and dlp are 100 in length.
xdots should be 100 in length. xdots has the correct values, but the length of xdots is less than 100.
prin / xdots; * is 87
xdots is only from the first trigger==1 is TRUE to the last trigger==1 is TRUE.
and on View -> Series Window is 87 in length.
Why would that be? And how to SET xdots to be 100 in length i.e. including the NA's?
dat.txt
(2.46 KiB) Downloaded 9971 times
You've already done that:
stats xdots 1 100
Statistics on Series XDOTS
Observations                     4      Skipped/Missing                  96
Sample Mean              -0.023320      Variance                   0.000039
Standard Error            0.006266      SE of Sample Mean          0.003133
t-Statistic (Mean=0)     -7.443046      Signif Level (Mean=0)      0.005020
Skewness                 -0.091471      Signif Level (Sk=0)        0.963521
Kurtosis (excess)        -4.870002      Signif Level (Ku=0)        0.586109
Jarque-Bera               3.958399      Signif Level (JB=0)        0.138180
If you ask the program to figure out the length (with STATS or PRINT without the length), it will truncate to start at the first non-NA and truncate at the last non-NA. But if you created it to length 100, it will know that it's length 100 if you try to use the entries. For instance,
?xdots(100)
will properly show NA while
?xdots(500)
will show
##undefined##
This has been fixed with 11.1.
