Tsay JASA 1998 Threshold VAR
These are "replications" for Tsay (1998), "Testing and Modeling Multivariate Threshold Models", J. of American Statistical Assn, vol. 93, no. 443, 1188-1202. Note that the calculations in the paper had a serious programming error with the log likelihoods being computed incorrectly. (I'm fairly sure that instead of using - T/2 log |Sigma|, they used - T/2 log |T Sigma|). This forced the estimates towards breaks that are roughly equally spaced. The calculations here use the proper likelihoods.
The theory in the paper and the US interest rates example is covered in detail in the 2nd Edition of the Structural Breaks and Switching Models e-course
Zip with programs and data files
Detailed description
Trankied
Tsay(1998) TVAR Model
@gridseries(from=-.30,to=.05,n=80,pts=ngrid) rgrid
compute bestaic=%na
do i=1,ngrid-19
do j=i+20,ngrid
sweep(group=(thresh<rgrid(i))+(thresh<rgrid(j)),var=homo)
# g3year g3month
# constant g3year{1 to p} g3month{1 to p}
compute thisaic=-2.0*%logl+2.0*%nregsystem
if .not.%valid(bestaic).or.thisaic<bestaic
compute bestaic=thisaic,bestlower=rgrid(i),bestupper=rgrid(j)
how to determine 19,20 and what's it means?
thanks for helping
Trankied
Re: Tsay(1998) TVAR Model
thanks for answer
BTW,the code above
I would like to know why set i=1,ngrid-19 and j=i+20,ngrid.
Could you please interpret what they means?
thans for answering
BTW,the code above
do i=1,ngrid-19
do j=i+20,ngridCould you please interpret what they means?
thans for answering
If you're doing a grid search for two breaks, the second break point has to come after the first. You also want to make sure that the two have a gap between them.
do i=1,ngrid-19
do j=i+20,ngrid
has I as the subscript for the first break point and J as the second. In order to allow for 20 grid points between them, I can't go beyond ngrid-19, and J has to start at I+20.
do i=1,ngrid-19
do j=i+20,ngrid
Trankied
I am appreciate your great help. It's very useful for me.
I have another question:
If I wanna estimate two threshold value for three-regime model, first threshold value get by [-0.3,-0.2],the other by [-0.15,0.05]
How should I code on this example?
The overall lower and upper bounds are already -.3 and +.05 (note the @GridSeries). If you want to put hard restrictions on the two ranges, you just have to figure out the upper bound for I, and the lower bound for J that correspond to grid values of -.2 and -.15 respectively.Trankied wrote:I am appreciate your great help. It's very useful for me.
Trankied
so if I wanna choose lower break by 15%~40% and upper break by 57%~85%,
If there are 100 data available, could I set i=15,40 j=57,85 and n=100 ?
instead of estimating two break separately, I wanna estimate them at the same time and use AIC to determine it.
How should I code it?
Trankied
another question:
if I would like to set threshold is delayed X.
I should or
I should
set thresh =X{1} Code: Select all
set thresh = X{-1}-
The FROM and TO limits on the @GRIDSERIES are already set to exclude the most extreme values since you need a certain amount of data just to estimate the models. I'm not completely sure what you mean by the percentages, but the Tsay coding is using an equally-spaced grid, rather than a grid based upon empirical values. The principal reason for that is that the number of potential regressions for an empirical grid was too large to be feasible at the time the paper was written.Trankied wrote:so if I wanna choose lower break by 15%~40% and upper break by 57%~85%,
RATS uses x{n} for lag n, so you want x{1}. x{-1} would be for lead 1.Trankied wrote:another question:
I shouldorCode: Select all
set thresh =X{1}Code: Select all
set thresh = X{-1}
yizhuorui
Re: Tsay JASA 1998 Threshold VAR
Dear tom,
I choose a SUR instruction to pick the threshold since my model is a near-VAR.(In fact, i identified error correction term through the Cats and restricted some variable to weekly exogeneity,and added with some dummy variable ,and then every equation become diffrent ,so i have to choose to SUR instruction instead of sweep instruction)
However ,the output demonstrated “## REG13. Singular Regressions - Check for Collinearity among Rows 1 to 1.”。what should i do to fix this error?(when i didn't add some dummy variable,the result is the same.) I attached with my data
equation wtii wti
# constant exchangerate{1 to p} CPI{1 to p} output{1 to p} wti{1 to p} monetary{1 to p} dummywti1 dummywti2 dummywti3 dummywti4 dummywti5
equation exchangeratee exchangerate
# constant exchangerate{1 to p} CPI{1 to p} output{1 to p} wti{1 to p} monetary{1 to p} dummyexchangerate1 dummyexchangerate2 dummyexchangerate3
equation cpii cpi
# constant exchangerate{1 to p} CPI{1 to p} output{1 to p} wti{1 to p} monetary{1 to p} dummycpi1 dummycpi2 $
dummycpi3 dummycpi4 dummycpi5 dummycpi6 dummycpi7 dummycpi8 dummycpi9 dummycpi10 dummycpi11 dummycpi12
equation outputt output
# constant exchangerate{1 to p} CPI{1 to p} output{1 to p} wti{1 to p} monetary{1 to p} ect dummyoutput1 dummyoutput2 $
dummyoutput3 dummyoutput4 dummyoutput5 dummyoutput6 dummyoutput7 dummyoutput8 dummyoutput9 dummyoutput10 dummyoutput11 $
dummyoutput12 dummyoutput13 dummyoutput14 dummyoutput15 dummyoutput16 dummyoutput17 dummyoutput18
equation monetaryy monetary
# constant exchangerate{1 to p} CPI{1 to p} output{1 to p} wti{1 to p} monetary{1 to p} dummymonetary1 dummymonetary2
group yzr wtii exchangeratee cpii outputt monetaryy
set thresh = wti{7}
@gridseries(from=-0.083106944,to=0.060975559,n=147,pts=ngrid) rgrid
set aic 1 ngrid = 0.0
compute bestaic=%na
set bic 1 ngrid = 0.0
set cic 1 ngrid = 0.0
compute rtest=rgrid(i)
sur(model=yzr,noprint,nosigma,smpl=thresh>rtest)
compute bic(i)=-2.0*%logl+2.0*71
sur(model=yzr,noprint,nosigma,smpl=thresh<rtest)
compute cic(i)=-2.0*%logl+2.0*71
compute aic(i) = bic(i)+bic(i)
if i==1.or.aic(i)<bestaic
compute bestaic=aic(i),bestbreak=rtest
scatter(footer=$
"AIC Values for Interest Rates Regression vs Break Point")
# rgrid aic
disp "Best Break is" bestbreak "with AIC" bestaic- Attachments
- 199602开始差分汇率没用的x12.csv
- (24.27 KiB) Downloaded 1408 times
Without a full program, I can't really tell, though I assume you want ECT{1}, not current ECT, unless you defined ECT with a lag to start. I'm not really understanding the point of dozens of dummies with a threshold model. The dummies and the threshold model are two rather distinct ways to deal with structural breaks and they don't necessarily work together well. You may very well be running into SUR's that can't be estimated due to the lag of data points in a partition.
Bach
I am using the Tsay threhold program to determine the threshold for my 3 variable VAR ( using one of the Variable in the model, output) as the threshold. I am however getting an error message. Does the TSAY code allow such configuration ? Do you see any issue with the code below ?
Alternatively, if I now use the TsayTest procedure to do the same, would the next instruction produce the same accurate result ( or should I remove the dgdp ( which is the threshold) from
# constant dspen100{1 to p} dgdp100{1 to p} dtax100{1 to p} ? as I am getting d=1 is significant under the latter scenario but insignificant if on the ocntrary I include the dgdp in the equation .
compute sstart = 2000:3
compute send = 2014:1
set dgdp = gdp - gdp{1}
set dspen = spen - spen{1}
set dtax = tax- tax{1}
set dgdp100 = 100*dgdp
set dspen100 = 100*dspen
set dtax100 = 100*dtax
@dfunit(lags=12) dgdp
@dfunit(lags=12) dspen
@dfunit(lags=12) dtax
spgraph(vfields=3,$
footer="Figure 3. Time Plots of Growth Series of Tunisian Fiscal Variables")
graph(vlabel="Output")
# dgdp100
graph(vlabel="Government Spending")
# dspen100
graph(vlabel="Tax")
# dtax
@VARLagSelect(lags=12,crit=aic)
# dspen dgdp dtax
compute p =2
compute k =3
do d=1,3
dofor m0 = 50 100
set thresh = dgdp100{d}
rls(noprint,order=thresh,condition=m0) dspen100 / rrspen
rls(noprint,order=thresh,condition=m0) dtax100 / rrtax
rls(noprint,order=thresh,condition=m0) dgdp100 / rrgdp
* We need to exclude the conditioning observations, so we generate
* the series of ranks of the threshold variable over the
* estimation range.
order(ranks=rr) thresh %regstart() %regend()
linreg(noprint,smpl=rr>m0) rrspen / wrspen
linreg(noprint,smpl=rr>m0) rrtax / wrtax
linreg(noprint,smpl=rr>m0) rrgdp / wrgdp
ratio(mcorr=%nreg,degrees=k*%nreg,noprint)
# rrspen rrtax
# wrspen wrtax
# rrgdp rrspen
# wrgdp wrspen
# rrgdp rrtax
# wrgdp wrtax
disp "D=" d "m0=" m0 @16 "C(d)=" *.## %cdstat @28 "P-value" #.##### %signif
end dofor m0
end do d
* Evaluate the AIC across a grid of threshold settings
set thresh = dgdp{1}
@gridseries(from=-4,to=3,n=300,pts=ngrid) rgrid
compute bestaic=%na
do i=1,ngrid
sweep(group=thresh<rtest,var=homo)
# dspen100 dgdp100 dtax100
compute aic(i)=-2.0*%logl+2.0*%nregsystem
scatter(footer="AIC Values for Interest Rates Regression vs Break Point")
# rgrid aic
***** /////***** to estimate double break
* This is a slightly different set of grids than used in the paper.
@gridseries(from=-4,to=5,n=80,pts=ngrid) rgrid
compute bestaic=%na
do i=1,ngrid-19
do j=i+20,ngrid
disp "Best double break is at" bestlower "and" bestupper "with AIC" bestaic
do d=1,4
set thresh = dgdp{d}
@tsaytest(title="Threshold Test with Delay="+d,thresh=thresh) dgdp100
end do d
* And with reversed ordering
do d=1,4
set thresh = -dgdp{d}
@tsaytest(title="Threshold Test Reversed with Delay="+d,thresh=thresh) dgdp
end do d
- FISCAL_3var_Final - Copy.xls
- (30 KiB) Downloaded 1091 times
Tsay can be extended to three (or more). You just need to do two sets of three series on the RATIO instruction, just adding the corresponding series for the third variable.
Bach
Thanks Tom for the quick response. I changed the code as suggested which now reads as follows;
However , I am now getting this error message '
Any idea what the cause of the above might be ?
# rrspen rrgdp rrtax
# wrspen wrgdp wrtax
The Error Occurred At Location 1698, Line 29 of loop/block
## REG6. Matrix VCV-1 Is Singular. Check for Collinearity in First 3 series
## REG6. Matrix VCV-2 Is Singular. Check for Collinearity in First 3 series
## M1. MCORR = 7 is Illegal. Value should be between 1 and 1
D= 1 m0= 50 C(d)= NA P-value NA
The Error Occurred At Location 1118, Line 20 of loop/block
