Dear TOM:
While I estimate 4 variate MVgarch,var(p)-MVgarch-BeKK, I use var as mean equation. However, @varlagslecet procedure gives different result, different var lags,eg, p, lead to different results of covariance - equation.
aic is 7, SBC is 1, HQC is 3.
How can I do?
haardmann.
how to select var lag in MVGARCh
hardmann
- oil price.RPF
- (738 Bytes) Downloaded 1158 times
- oil price.xls
- (71.5 KiB) Downloaded 1000 times
moderator
- Site Admin
Re: how to select var lag in MVGARCh
With respect to VAR models in general, it's not uncommon to see conflicting results from the various lag-selection algorithms. In those cases, you really just need to consider the data carefully and use your best judgment. You may want to try different models, and do some tests on specific lag lengths (i.e. tests on omitting longer lags).
If you will ultimately be estimating the VAR as an MVGARCH model, the lag-selection statistics are of even less value. For the MVGARCH case, we would recommend that you choose a fairly small number of lags, and test the resulting standardized residuals for remaining autocorrelation.
Tom Maycock
Estima
Tom Maycock
Estima
