Dear all
when I try to use the condition.prg program, I get the following result :
## OP3. This Instruction Does Not Have An Option MOD
>>>>@condition(model=<<<<
Has any one already met this problem with this procedure ?
Best regards
Christophe Tavéra
procedure condition.src
Re: procedure condition.src
Check to make sure you aren't using a very old version of the procedure file--one that dates back to when we were using parameters, not options (although I think the pre-model versions were still called CNDITION to fit the old 8-character filename constraint, rather than CONDITION).
Open up the condition.src and see what it describes for the syntax, and then make sure that's the copy of the procedure that is getting SOURCE'd in.
If you are still having problems, email your program and data files, and your copy of CONDITION.SRC to us at support@estima.com. Be sure to include your RATS serial number and the version you are using (do Help-About RATS to verify that).
Tom Maycock
Tom Maycock
