MBDEMO.PRG and GDPQ.RAT
iloverats
Unread post by iloverats »
why MBDEMO.PRG and GDPQ.RAT can not be download?
Used with MODES.SRC, this bootstraps series and tests against an alternative number of modes. Requires MBKERNEL.SRC (a stripped-down version of the KERNEL.SRC procedure).
Re: MBDEMO.PRG and GDPQ.RAT
Here they are:
MBDEMO.PRG
(1.43 KiB) Downloaded 1023 times
GDPQ.RAT
(2.25 KiB) Downloaded 1051 times
iloverats
TomDoan wrote:Here they are:
MBDEMO.PRG
GDPQ.RAT
This does run well
it dispaly" ## SR10. Missing Values And/Or SMPL Options Leave No Usable Data Points
The Error Occurred At Location 1412 of MODES
Line 55 of MODES"
may you give me a exmple code of silverman's multimodality test ?
thank you very much
This is an updated version of the MODES procedure and a corresponding update to the demo program. (I fixed a bug in MODES and switched the control parameters to options rather than parameters).
modes.src
Procedure file
(5.56 KiB) Downloaded 1147 times
MBDEMO.prg
Example file
(1.47 KiB) Downloaded 1179 times
