Command MATRIX
For questions that don't fall into one of the categories above, such as working with the RATS interface, using Wizards, etc.
rmendez
Command MATRIX
Unread post by rmendez »
I have stumble across upon a RATS code that use the command MATRIX,
for which I don't find any description in the documentation.
I suppose this command has been superseded by COMPUTE. Am I right? What was this COMMAND about? Is it a C++ command?
Thanks in Advance for any hint
Rodolfo
TomM
Unread post by TomM »
In the old days, one had to use specific commands for real computations (EVAL), integer computations (IEVAL), and matrix computations (MATRIX).
Those were all superseded by the COMPUTE instruction, which I believe was introduced in Version 4. The old commands are still supported, but for any new coding, you'll want to use COMPUTE.
Tom Maycock
Estima
support@estima.com
