Q stat DCC GARCH
aymenbelgacem
Q stat DCC GARCH
Hi
I'm using an old version of Engle(2002) JBES for the DCC GARCH and I would like to calculate the MV Qstat
Is there any suggestion plz.
I don't use the GARCH instruction to estimate the model because I would like to introduce some other variables in GARCH and Q equations...
This is a part of the code
Aymen
Aymen
- dcc engle.PRG
- (2.5 KiB) Downloaded 1282 times
Re: Q stat DCC GARCH
Do you mean something other than the @MVQSTAT procedure?
aymenbelgacem
Yes I mean the @mvqstat but I don't know how to treat the dynamic correlation before using the procedure
Thanks Tom
Thanks Tom
The GARCHMV.RPF example includes multivariate standardization of the residuals prior to calling @MVQSTAT:
garch(p=1,q=1,pmethod=simplex,piters=10,$
hmatrices=hh,rvectors=rd) / xjpn xfra xsui
set z1 = rd(t)(1)/sqrt(hh(t)(1,1))
set z2 = rd(t)(2)/sqrt(hh(t)(2,2))
set z3 = rd(t)(3)/sqrt(hh(t)(3,3))
@bdindtests(number=40) z1
@bdindtests(number=40) z2
@bdindtests(number=40) z3
* Multivariate Q statistic. This requires transforming the residuals to
* eliminate the time-varying correlations.
dec vect[series] zu(%nvar)
do time=%regstart(),%regend()
compute %pt(zu,time,%solve(%decomp(hh(time)),rd(time)))
end do time
@mvqstat(lags=40)
# zu-
aymenbelgacem
Thanks Tom
I know this example but I can't use the GARCH instruction and the Xregressors because I want to add the lagged variance of the market i in the market j and other variables, so I tried to paste the second part of GRACHMV example in which one calculates the standardized residuals. But the problem that I tried to make a link between it and my version of the DCC GARCH attached above, I didn't find what corresponds to "hh" and "rd" in my old version of the DCC.
Sorry Tom for this (naive) question
Your equivalent would be to use %XT for the HH and U arrays of series:
dec vect[series] zu(n)
compute %pt(zu,time,%solve(%decomp(%xt(hh,time)) ,%xt(u,time)))
end do time-
aymenbelgacem
I don't have HH. Do you mean h?
moderator
- Site Admin
It would be whatever name you are using for your variances and covariances in your particular code. Mr. Doan used HH in his example, but it looks like you used H in your code.
Tom Maycock
Tom Maycock
