question about Beveridge-Nelson and Unobserved-Components De
hardmann
Dear Tom:
I repeat the example of Morley, Nelson & Zivot(2003), "Why Are the Beveridge-Nelson and Unobserved-Components Decompositions of GDP So
Different? When I substitute Chinese quarterly real GDP seasonally adjusted and slightly alter origin code, I encounter some problem. When I estimate UC-UR, I get rho 1.25, which is rather positive than negative and more than 1. I am not sure that before estimating BN model, the ARIMA(p,q) form must be specified. When I use rgdp data adjusted by X12, I get ARIMA(2,1,2). According to this specification, my result is different form standard procedure @bndecomp. I do not know what is up?
Attached is my data. I plea you examine my data if possible.
Best regards.
hardmann
Best regards.
hardmann
- china_1994.RPF
- (2.7 KiB) Downloaded 1199 times
- china_gdp.XLS
- chinese rgdp
- (20.5 KiB) Downloaded 1030 times
Re: question about Beveridge-Nelson and Unobserved-Component
You have a rather short data set for this type of analysis. MNZ had 50 years; you have 16. The first difference of GDP is fairly close to white noise so the estimates of ARMA(2,2) models aren't very precise---if you change your method you get very different estimates. If you put a PRINT on the BNDECOMP procedure (that's why it's there!!) you'll see that it doesn't converge on an ARMA(2,2) model with the set of options used by the procedure (which has the series de-meaned first). De-meaning the series first versus estimating the mean as part of BOXJENK should give almost identical results in large samples, but this is small enough that they don't.
April86
a question about source of China's real GDP data
Hi hardmann,hardmann wrote:Dear Tom:
Best regards.
hardmann
I came across your post when searching RATS codes for UC decomposition. As far as I know, China only releases nominal GDP and real GDP growth rate since 1992:Q1. I can only find quarterly real GDP data (in 2010 price) since 2011 and yearly GDP deflator since 1978. I am wondering where you got the real GDP data? Did you compute it as the ratio between nominal GDP and CPI or did you imputed it from real GDP growth rate?
Thanks a lot!
Xue
hardmann
Dear Xue:
Sorry. I answer your question up to now. According to chinese statistics yearbook, we can get annualy nominal GDP and index of real gdp based on 1978=100, so calcaulate annuanly deflator GDP. we also get quarterly nominal GDP form website of Chinese statistic agency. We then use annualy deflator to deflat quarterly nominal gdp, and get real quarterly GDP then use Denton method to adjust it.
Best
Hardmann
Best
Hardmann
