Weakly exogenous VECM
lambert89
I am new to using RATS and am struggling a bit at the moment. I want to estimate a VECM model with consumption and output as the dependent variables, then I want to impose weak exogeneity so that only the change in output is affected by the error correction term, that is, the error correction term in the (change in) consumption equation is restricted to zero.
So far I have:
lin(define=acony) ca 1984:1 2011:4 resids
# constant ya
system(model=avecm)
var ca ya
lags 1
ect acony
estimate(outsigma=s, residuals=resid) 1984:1 2011:4
Any help or hints would be greatly appreciated.
Regards
So far I have:
# constant ya
system(model=avecm)
var ca ya
lags 1
ect acony
Regards
Re: Weakly exogenous VECM
That's fairly easy to do with CATS. With RATS, the easiest way to do it is to estimate the model both with and without the cointegrating vector (actually, to get the setup to be parallel, with a "fake" cointegrating vector in the second case) and replace the coefficients for the equation that needs the restriction. Doing this lets RATS handle all the differencing and undifferencing.
open data swjasa.rat
calendar(q) 1960
all 1979:8
data(format=rats) / fyff fygm3 fygmyr
cmom
# fyff fygm3 fygmyr
eigen %cmom eigval eigvec
* Set the cointegrating vector into an error correction equation
equation(coeffs=%xcol(eigvec,3)) rcoint
# fyff fygm3 fygmyr
* And make a second copy of it with zero coefficients
equation(coeffs=%zeros(3,1)) rfake
# fyff fygm3 fygmyr
* Original ECM model
system(model=ratemodel)
var fyff fygm3 fygmyr
lags 1 to 4
ect rcoint
estimate(noprint)
* Parallel model with the zeroed out ECT
system(model=fakemodel)
lags 1 to 4
ect rfake
estimate(noprint)
* Pull the two sets of coefficients
compute ecmcoeffs=%modelgetcoeffs(ratemodel)
compute ecfcoeffs=%modelgetcoeffs(fakemodel)
* Replace the coefficients for the 3rd equation
compute %psubmat(ecmcoeffs,1,3,%xcol(ecfcoeffs,3))
* And reset them in the main model
compute %modelsetcoeffs(ratemodel,ecmcoeffs)-
lambert89
Thank you very much for the help.
