i was trying to apply a shock on a system of three prices VECM. if the date of applying the shock changed does it change the results of the impulse responses? if yes i need your help of how to change the date of applying the shock using the instruction IMPULSE.
thank you so much for your help.
fadi
Date of applying a shock on VECM
Re: Date of applying a shock on VECM
No. The response of a VECM to a shock is independent of the initial conditions. So you can just use IMPULSE.
