Hi there,
I could not find any code that extend the Markov Switching GARCH model of Gray (JFE, 1996) to the MV-GARCH context. Could you please help with RATS coding this model given in pg.477-478 in the paper attached?
Thank you
Markov Switching MV-GARCH
- AngChen AsymmetricCorrelations.pdf
- Markov Switching MV-GARCH page 477-478
- (607.91 KiB) Downloaded 802 times
Re: Markov Switching MV-GARCH
I'm not a great fan of Gray's method; Dueker's filter seems to work quite a bit better. (Both of them require an approximation to replace the complicated history with a single result for each regime; Dueker's waits longer to do the collapsing).
thanks for this.
I was after a bivariate garch extension. Is this possible?
thanks for this.
