I'm on the CH IV " New Introduction To Multiple Time Series analysis" I'm dealing with the Numerical Problems p.191
Problem 4.6 based on the file E2
which is related to section 4.2.4.Set up a sequence of tests for the correct VAR order of the data generating
process using a maximum order of M = 4. Compute the required χ2 and F
likelihood ratio statistics. Which order would you choose?
To answer the question i write the program:
OPEN DATA "C:\Users\amaraoui nabih\Desktop\ECONOMIE\MANUELS\NEW INTRODUCTION TO MULTIPLE TIME SERIES ANALYSIS\Problems CH IV p191\E2.txt"
CALENDAR(Q) 1947:1
DATA(FORMAT=PRN,ORG=COLUMNS) 1947:01 1972:04 y1 y2
@varlagselect(crit=gtos,det=constant,lags=4) * 1972:4
# y1 y2
VAR Lag Selection
Lags F-Test
0 0.000000*
1 526.013725
2 45.768352
3 4.783891
4 6.805817
So i checked the appropiate program from Lütkepohl which is related to this table 4.4:
Lutkepohl, New Introduction, example 4.2.4 from pp 145-146
* VAR; Lag selection
open data e1.dat
calendar(q) 1960
data(format=prn,org=columns,skips=6) 1960:01 1982:04 invest income cons
set dinc = log(income/income{1})
set dcons = log(cons/cons{1})
set dinv = log(invest/invest{1})
@varlagselect(crit=gtos,det=constant,lags=4) * 1978:4
# dinc dcons dinv
VAR Lag Selection
Lags F-Test
0 0.0000000*
1 23.2488409
2 24.9009035
3 4.7563989
4 14.4383478
The column that supposed to follow a khi2 distribution up here follows a F-Test?
Do you see what i mean?
And how does he get the critical values?
My second question still about Order Selection is page 148:
i don't find the same results even with the Lütkepohl program
* Lutkepohl, New Introduction, example 4.3 from p. 148
open data e1.dat
calendar(q) 1960
@varlagselect(lags=4,det=constant,crit=aic) * 1978:4
# dinc dcons dinv
@varlagselect(lags=4,det=constant,crit=sbc) * 1978:4
# dinc dcons dinv
@varlagselect(lags=4,det=constant,crit=hq) * 1978:4
# dinc dcons dinv
VAR Lag Selection
Lags AICC
0 -1123.4537
1 -1127.2573
2 -1130.8805*
3 -1112.2548
4 -1100.8783
VAR Lag Selection
Lags SBC/BIC
0 -1116.7804*
1 -1101.6652
2 -1088.2020
3 -1054.5942
4 -1030.6685
VAR Lag Selection
Lags HQ
0 -1120.8691*
1 -1118.0198
2 -1116.8225
3 -1095.4807
4 -1083.8209
I hope my questions are clear enough.
Thanks a lot Tom
