FFT/IFT
atrad
FFT/IFT
Unread post by atrad »
I would like to obtain the covariogram from the periodogram for a time series. To do this I first use rtoc using twice the number of observations, then apply fft, followed by cmult(scale=1/2*%nobs) and then ift. This I scale by 1/2*%pi. I appear to obtain the covariogram but it seems to only start with the first autocovariance. Will I never obtain the contemporaneous variance this way?
Re: FFT/IFT
atrad wrote:I would like to obtain the covariogram from the periodogram for a time series. To do this I first use rtoc using twice the number of observations, then apply fft, followed by cmult(scale=1/2*%nobs) and then ift. This I scale by 1/2*%pi. I appear to obtain the covariogram but it seems to only start with the first autocovariance. Will I never obtain the contemporaneous variance this way?
The covariance should be in entry 1. The only scaling needed in this sequence is 1.0/actual observations. The 1/(2pi) is rather specific to a final estimate of the spectral density. The following sequence computes the covariogram using frequency domain operations and gives the same results as the cross instruction with the covariances option.
seed 3439
set x 1 100 = %ran(1.0)
diff(center) x / cx
freq 1 2*%freqsize(100)
rtoc
# cx
# 1
fft 1
cmult(scale=1.0/100.0) 1 1
ift 1
cprint 1 10 1
corr(covar,method=yule,number=9) cx
