Koutmos JBFA 1996 Multivariate EGARCH
The following estimates a multivariate E-GARCH model with a VAR(1) mean model and spillovers in the GARCH specification. This is from G. Koutmos(1996) "Modeling the Dynamic Interdependence of Major European Stock Markets", Journal of Business Finance and Accounting, Vol. 23, pp. 975-988. The program should require relatively little change to be adapted to other data.
This program is covered in considerable detail as part of the ARCH, GARCH and Volatility e-course.
Version 9 of RATS adds the option VARIANCES=KOUTMOS to allow direct estimation using the GARCH instruction.
vegarch.rpf
Program file
(6.24 KiB) Downloaded 1416 times
vegarch9.rpf
Program for Version 9 or later
(3.12 KiB) Downloaded 1293 times
stock9.rat
Data file
(117.25 KiB) Downloaded 1275 times
prashantj
Re: Koutmos JBFA 1996 Multivariate EGARCH
Unread post by prashantj »
I am using two stock market series of japan and hongkong. When I have modified the programme of koutmos to suit my need. When I have run the programme, I have got the following message:
## REG20. GARCH Cannot Be Used with Gaps/Missing Values
could you please recommend me the solution? Please.
Prashant
You can't have any gaps (missing values) within the range that GARCH uses. Apparently you do. You'll have to figure out how you plan to deal with that and fix it.
prashantj
I have been using Koutmos JBFA 1996 Multivariate EGARCH programme for my data set. Both programme and the data set are attached. I have encountered a serious problem when I use it with RATS which
is as follows: My version of RATS is 8.3 standard.
When I run the programme with modification as per my requirement, the processing take unusual time to such an extent that RATS cannot generate output even after 50 minutes. I fail to figure out solution for the problem. Could you please help me? and oblige, please.
Looking forward for your reply,
With regards,
Prashant
ASMN.xls
Dataset
(93 KiB) Downloaded 993 times
programme.RPF
programme for my dataset
(6.24 KiB) Downloaded 1186 times
Did you let it run longer? That has 80 parameters, a relatively long data set and a fairly complicated likelihood function. It's going to take a while. If you want some feedback, add a TRACE option to the MAXIMIZE instruction.
prashantj
yes, i allowed to let it go longer to more than one hour but of no avail. still RATS is processing it though The number of data set or observation are way less than what Koutmos's paper included. Could you please suggest the way out?
Prashant
If you're concerned, cancel it and re-run it with the TRACE option on.
You're using five variables rather than four. The increase in the number of parameters is more significant than the somewhat shorter data set.
It's actually 85 parameters---you forgot to add the 5th variable to the mean equation, which is supposed to read:
equation meaneq *
# constant y(1){1} y(2){1} y(3){1} y(4){1} y(5){1}
You also have almost no contemporaneous correlation among your variables---many of the CC's are less than .01 in absolute value.
prashantj
If there are no contemporaneous correlation among variables, will it be worth examining volatility spillover using koutmos EGARCH model? I have read somewhere that even if there is poor correlation or no correlation, there can be a possibility of volatility spillover among the markets. looking forward for your reply,
Prashant
Is it possible? Yes. Is it unlikely that there's spillover when there's such a weak connection? I think also yes.
prashantj
I run the programme with little change to adapt to my requirement. I have got R(2,1) in table 1 and R(2,2) in table 2. But I could not get both at the same time in both the tables. I would like to know what does R indicate? Does it mean correlation coefficient? Does it make any any difference if R(1,1) and R(2,1) omitted in Table 1 and Table 2 respectively?
Another thing is t-statistics for coefficients of B(1) and B(2) in table 1 and G(1) and G(2) in table 2 , B(1) and B(2) in table 3 are very high even more than 100. Does it convey something wrong with the model or nothing to worry. I have attached the output, programme and data set for your reference, please.
Prashant
indiaus1.xls
dataset
(58.5 KiB) Downloaded 1005 times
PROGRAMMEIU1.RPF
programme
(6.11 KiB) Downloaded 1276 times
output file.RPF
analysis
(9.32 KiB) Downloaded 1277 times
Don't do 100 simplex iterations. You're already at the optimum by the time you're done with that, so the BFGS estimates of the curvature (used for the standard errors) are wrong.
The correlations are modelled using the packed subdiagonal matrix. GARCH does the same thing, but GARCH knows the proper way to label those. When you use MAXIMIZE, the correlation matrix has the form
1
R(1,1) 1
R(2,1) R(2,2) 1
so the R(1,1) is, in fact, the 2,1 correlation.
f_ta
Unread post by f_ta »
I am trying to use the VAR-EGARCH code of Koutmos, modified to bivariate with an exogenous variable in the mean model, on my data. I get the following warning:
NO CONVERGENCE IN 51 ITERATIONS
LAST CRITERION WAS 0.0000000
SUBITERATIONS LIMIT EXCEEDED.
I read the forum and understood that this is only a warning, as also the vegarch.rpf-code states. However, how can I verify that my model actually converges if this warning appears? Sorry, I am new to RATS, and I would greatly appreciate any help with this.
Code and data below.
Best regards,
Amanda
5ykod.RPF
Code
(3.85 KiB) Downloaded 1244 times
Datafnr.xls
Data
(143 KiB) Downloaded 1023 times
all 1 1292
open data h:\Datafnr.xls
data(format=xls,org=obs) / eurf usdf eursteep usdsteep
compute n=2
compute gstart=3:1292,gend=1292:1292
dec vect[series] y(n)
set y(1) = (eurf-eurf{1})
set y(2) = (usdf-usdf{1})
dec vect[series] s(n)
set s(1) = (eursteep-eursteep{1})
set s(2) = (usdsteep-usdsteep{1})
1. Not that it affects the results, you want
all 1292
and
compute gstart=3,gend=1292
This is an irregular time series data set, so you don't want to even try to use dates.
2. Don't you want
to be log differences? Level differences looks wrong.
3. This is probably what creates the problem:
Again, should those be log differences? But more important, should you have those in your mean model contemporaneously rather than with a lag? Those two have very large, very, very significant coefficients in the mean model, which probably would only happen if they were being determined simultaneously with the dependent variables.
f_ta
Thank you for your prompt reply. Changing the xsteep variables to contemporaneous still did not lead to convergence. I also tried leaving out the exogenous variable and did not get any valid results.
As I have several datasets some of which include negative values, I do not think that log-returns will work. I am trying to do a similar study as In (2007) Volatility spillovers across international swap markets: The US, Japan, and the UK, and Toyoshima & Hamori (2012) Volatility transmission of swap spreads among the US, Japan and the UK: a cross-correlation function approach, where both state that they are using first differences.
Is it possible to change the distribution in the maximize function to t-distribution?
Thank you for your help, it is highly appreciated.
Best regards,
Amanda
