Graphics
Posted: Tue Dec 17, 2013 10:30 am
by bbks40
We have a problem with saved graphs in eps-format. Sometimes the left side and sometimes the right side of the graph is truncated. With GhostView and with Adobe (distiller) we get the same results. There seems to be a problem with the postscript driver used by WinRats (we use Version 8.2 from 2012/09/21). With version 7.3 we had no problems.
Re: Graphics
Posted: Tue Dec 17, 2013 11:22 am
Is it possible that you had edited the prolog.pst file for the earlier version? If you want an A4 target you have to change the last line in the below to
/RGFHORZ where {pop} {/RGFHORZ -781.2 def/RGFVERT 10.8 def} ifelse
% For Letter size (11" x 8.5") (792 points x 612 points)
% -756 18 translate
% For A4 size (11.7" x 8.3") (842.4 points x 597.6 points)
% -781.2 10.8 translate
% For EPS import, use -(4th element in %%BoundingBox) 0
% If RGFHORZ and RGFVERT are not set above to the appropriate values
% the following line will define them.
/RGFHORZ where {pop} {/RGFHORZ -756 def/RGFVERT 18 def} ifelse
