Hi everyone,
I'm fitting a bivariate garch-m model and found that when I change the order of the parameters in the model my results change!
So for example :
equation Aeq A
# constant A{1} hhs(1,1){1} hhs(2,2){1}
equation Beq B
# constant B{1} hhs(1,1){1} hhs(2,2){1}
gives a different results than:
equation Beq B
# constant B{1} hhs(2,2){1} hhs(1,2){1}
What would be the cause of this and what should I do to overcome this problem?
Thanks!
Parameter Order
Re: Parameter Order
You have a (1,2) in the second, and a (1,1) in the first.Anja wrote:Hi everyone,
So for example :gives a different results than:Code: Select all
equation Aeq A # constant A{1} hhs(1,1){1} hhs(2,2){1} equation Beq B # constant B{1} hhs(1,1){1} hhs(2,2){1}
What would be the cause of this and what should I do to overcome this problem?Code: Select all
equation Beq B # constant B{1} hhs(2,2){1} hhs(1,2){1}
Thanks!
