I have a question about what exactly VCV procedure calculates. I have two series, RGDP and UR. In Excel, CORREL function gives me one result (0.50225) and in RATS VCV command gives me a different result (0.97051).
I read in the manual that VCV computes a residual covariance matrix. But what is the exact formula? What residuals do they take as series? From LINREG?
The excel file with the raw data is attached.
I have tried
cross(org=column,from=0,to=0) UR RGDP
and
CMOMENT(CORR,PRINT)
# RGDP UR
WRITE %CMOM
and then received the same results as in Excel file. So now my question is what VCV is calculating.
Thank you very much.
Yelena
Compute a covariance matrix
yelena
- RGDP_UR_Raw_Data.xlsx
- (10.97 KiB) Downloaded 889 times
Re: Compute a covariance matrix
Without any other options, VCV computes the raw, uncentered covariance of the input series. The formula is in the User's Guide. It does not, itself, take residuals---it's usually applied to residuals. The Excel calculation subtracts means, which VCV will as well, if you use the CENTER option.
yelena
Oh, thank you, Tom. It works now.
