Hi
I want to estimate a multivariate model with a common "local level". I started out with a bivariate model with separate levels etc.:
(1) y1 = s1 + x1*b11 + x2*b12 + v1, where the y1 local level is a random walk s1 = s1(-1) + w1
(2) y2 = s2 + x1*b21 + x2*b22 + v2, where the y2 local level is a random walk s2 = s2(-1) + w2
(The next steps are imposing a common level s1 = s2, and allowing for missing y2 data at the end of the sample.)
All of the random errors are uncorrelated. I can estimate (1) and (2) individually with DLM, but I am not able to estimate (1) and (2) jointly. I need to do this when I impose the common local level.
My starting values from the separate estimates of (1) and (2) do not appear to work. I have obviously made some silly mistake, but I cannot spot it.
My Excel data file and Rats program file are attached. I would be grateful for any assistance.
Anthony
Multivariate Local Level Model
Rantmurph
- Income Forecast Data 15 Jan 2016.xls
- (51 KiB) Downloaded 849 times
- Income Forecasts 15 Jan 2016.RPF
- (3.1 KiB) Downloaded 941 times
Re: Multivariate Local Level Model
You're missing the Y option on the last DLM. BTW, I would recommend scaling the Y's up to 100 to get better scales on the variances.
